Author Topic: What's everyone using for speakers?  (Read 10072 times)
  • Last login:Yesterday at 07:09:41 am
Re: What's everyone using for speakers?
« Reply #40 on: October 06, 2009, 01:08:20 am »
+1 for the 2.1 speakers.  They sound great and the subwoofer is usually adjustable.
With mine however, I made sure that there was a separate volume control controller wire.  It makes it a lot easier.  I run mine underneath my control panel on the outside of the machine.  I just reach under when I want to adjust the volume or tweak the bass.
DeLuSioNaL29
ivwshane
    • My first mame cab! (WIP)
« Reply #41 on: October 06, 2009, 01:22:56 am »
I have a 2.1 ba735 pc speakers that I replaced the main speakers with a pair of 6x9's and kept the sub woofer.
Works perfect and required very little work to get working with windows.
Blanka
« Reply #42 on: October 06, 2009, 02:33:33 am »
The sound quality is extremely low bit rate for retro games and is completely wasted on high end speakers.
The first years they used analogue wave generators, which do not have a bit rate at all. But I can tell you, these classics sound way more impressive then ever on my two 180 watt Canton towers! Maybe not comparable to the original used PC-beeper, but hi-fi systems sound better than 2.1 PC sets I can assure you.
Beretta
« Reply #43 on: October 06, 2009, 03:47:10 am »
with a price tag to match, there really is'nt any difference except cost..
IE: you keep saying "PC speaker" OR "PC sets" when in actuality there are some high end sets you can buy for your computer.
it's all about cost rather then some fundamental defect in speakers geared for computers they're just usually cheaper is all.
you're right there is a difference between a 50 dollar set for your computer and a 500 dollar setup.
in most cases i'd have to agree though that the difference will be lost on most of us especially without side by side comparison and would completely destroy most peoples budgets.
Blanka
« Reply #44 on: October 06, 2009, 04:18:09 am »
High end needs 12-15cm drivers at least. So there are no high end computer sets. Just plain physics limitation.
Beretta
« Reply #45 on: October 06, 2009, 05:26:07 am »
sorry i really gotta plead the ignorance card, where did you come up with that figure?
HI-FI is the same as "high end" and usually is in reference to clarity of the sound (IE no distortion) where are you getting this "size" figure and i've seen plenty of small speakers sound better then larger so size is'nt every thing.
eaconner
  • Last login:February 27, 2013, 11:15:42 am
    • WV Arcade Club
« Reply #46 on: October 06, 2009, 09:47:47 am »
DeLuSioNaL29
My speakers have the same feature and I have it mounted in the same place. Mine also has a power switch on the volume control so I can turn them off when I am not using them.
« Reply #47 on: October 06, 2009, 10:33:29 am »
I wired up the volume and control panel for the speakers (I used a 2.1 computer speaker set), but, with CabVol running, I find I just don't need the volume controls. I crank them all the way up and use cabvol to actually adjust volume (I set it to use a hotkey along with one of the trackballs, acting like a mouse).
Works great.
