Author Topic: Copying a MAME Setup?  (Read 1019 times)
« on: September 20, 2009, 07:51:32 am »
OK, if I set up MAME exactly how I want it to run on one computer in, say, "C:\Arcade" then if I just copy that folder and everything in it to another computer will MAME run exactly the same?
elaverick
  • Last login:October 25, 2009, 09:18:45 am
Re: Copying a MAME Setup?
« Reply #1 on: September 20, 2009, 07:56:41 am »
Yes it should do.  I don't think MAME stores anything in the registry.
smalltownguy
  • Last login:October 07, 2025, 12:45:27 pm
« Reply #2 on: September 20, 2009, 08:07:38 am »
Mame doesn't but several other programs related to Mame do. My front end, for example, uses some system files that need to be installed prior to use. I also have some other add-ons that require .net 2.0 framework to run properly.
So I guess the answer to your question is 'maybe.'
BamBam
  • Last login:November 03, 2011, 07:18:19 am
  • This is better than Disney Land man!
« Reply #3 on: September 20, 2009, 08:19:32 am »
I use Mala RC 1.0 with MAME .109 and I have burned the image to a DVD.  I only have 450 games that I like and have culled all of the artwork etc. that I do not need.
I have successfully copied this image to another computer without an issue.
You will, however, be required to maintain your directory structure, otherwise you will need to re-map your paths i.e. C:\Arcade as is in your case.
Once that is done, I re-run the MALA installation file, even though MALA is in the image, so that any registry values are re-applied to the new computer.
So far it works for me.  :D
Galaga... Was there any other game?
severdhed
  • Last login:Yesterday at 11:58:45 pm
  • RIP Dinosaur Hippo
« Reply #4 on: September 20, 2009, 08:22:47 am »
when i set up my DK cabinet, i just copied my mame and mala directories from my other cabinet over to the new one, then just set up a new mala layout and smaller game list.. everything worked just fine
« Reply #5 on: September 20, 2009, 08:38:11 am »
Awesome.  This is for a MAME and MaLa setup.  I'm hoping to finally sort out my DK today and I have 5 new laptops I can tinker with.
