Author Topic: Bottom mounting question  (Read 1556 times)
Haterot
  • Last login:November 09, 2012, 09:27:41 am
« on: September 11, 2009, 04:42:36 pm »
I am going to bottom mount my U360 (on 5/8th plywood), anyone know how large a diameter hole I need for the shaft.  I am using the octaganol restrictos so the throw is limited by that. Any ideas?
Empire had the better ending. I mean, Luke gets his hand cut off, finds out Vader's his father, Han gets frozen and taken away by Boba Fett. It ends on such a down note. I mean, that's what life is, a series of down endings. All Jedi had was a bunch of Muppets
Re: Bottom mounting question
« Reply #1 on: September 11, 2009, 04:50:29 pm »
I used the same size hole as for standard happ buttons (I think it's a 1" hole?)
BUT I did route out about 1/4 inch on the bottom of 3/4" ply so the stick didn't sit so low.
Haterot
« Reply #2 on: September 11, 2009, 04:57:59 pm »
Im going to route out about 2mm for the faceplate but that is all. Im not sure I wan a 28mm hole. I would have to route out the circle a bit and put a dustwasher in there to flush it out, otherwise the cpo could tear at the hole.
