Author Topic: Mapping volume up and down buttons  (Read 2257 times)
bigster
  • Last login:June 16, 2022, 08:24:40 pm
« on: August 31, 2009, 04:38:41 pm »
Hi,
I want to map volume buttons to turn the volume up and down with hotkeys.  I tried some programs but they all seem to use the windows key along with another key (for example win+u for volume up).  This causes problems with mame and windows in general when I tried it (I am using an i-pac).
What I would like to do is to find a way to map a volume up system button (like the multimedia buttons on the front of a laptop for instance).  Does anyone know how to do this.  Or if you have suggestions on how to map the volume up and volume down to a pushbutton using an i-pac let me know.
Thank you.
TAG
  • Last login:May 23, 2014, 05:52:05 pm
Re: Mapping volume up and down buttons
« Reply #1 on: August 31, 2009, 04:49:04 pm »
CabVol should work for you.  It uses a hotkey, but it doesn't have to be the Windows key, and it works fine with the IPAC.
http://forum.arcadecontrols.com/index.php?topic=69901.0
I may not have gone where I intended to go, but I think I have ended up where I needed to be.
-- Dirk Gently
« Reply #2 on: August 31, 2009, 05:43:24 pm »
Second that. Cabvol works great, esp with a hotkey and spinner.
  • Last login:July 11, 2025, 09:17:44 am
« Reply #3 on: August 31, 2009, 06:17:45 pm »
I use CabVol and it works great.  Another vote from me for a great program.
D
XeviouS
  • Last login:March 11, 2016, 08:38:20 am
    • Noah's Arkade
« Reply #4 on: September 01, 2009, 03:47:30 am »
I use Volume Tray 2.0 which is configurable to any key. It boots up at 50% volume and lets you adjust the volume either direction by tapping on the chosen up and down keys. It's freeware:
http://www.brothersoft.com/volumetray-137145.html
surface tension
  • Last login:July 01, 2018, 08:45:48 am
  • feel the tension...
    • surface tension tables
« Reply #5 on: September 01, 2009, 04:13:36 am »
I also use volume tray. Very configurable and simple to use.
  • Last login:Yesterday at 02:28:11 pm
« Reply #6 on: September 01, 2009, 11:45:09 am »
I need to try these out...
Beretta
« Reply #7 on: September 01, 2009, 12:44:32 pm »
some games are louder then others, would be nice if mame saved the master volume slider.
surface tension
« Reply #8 on: September 01, 2009, 02:19:46 pm »
On a similar topic...
Is there a way of adjusting the volume in MAME directly, so a button for up and another for down? As opposed to bringing up the master volume then using the stick.
jtslade
  • Last login:February 13, 2025, 10:06:51 pm
  • Keep it looking originallish!
« Reply #9 on: September 02, 2009, 05:43:20 am »
Have you mapped a shifted function from your IPAC to the tilde ~ key ?
You can then change volume in mame during gameplay..
Ms. Pacman Original Cocktail with Non destructive mod to Groovy Arcade Linux with All 4way Vertical Cocktail capable 2 button or less games.
Neo Geo MVS Mame Cab Running Hyperspin, 25" Nanao Arcade Monitor, Mini-pac, ATI Radeon HD 4850 (ATOM-15), IL 8 Way Euro-Sticks from Paradise Arcade, Win XP 64bit, and tons of other junk.
surface tension
« Reply #10 on: September 02, 2009, 09:52:05 am »
Maybe I didn't explain myself very well. Is there a way of configuring a volume up and a volume down button without bringing up the master volume using the tilde key?
