Author Topic: GGG Tron Handles to Standard Joystick?  (Read 1214 times)
Dizzle
  • Last login:August 09, 2014, 05:28:04 pm
« on: August 22, 2009, 01:34:13 pm »
Has anyone had any luck fitting the Tron/Satan's Hollow handles from GroovyGameGear to standard Happ competition joysticks?
arzoo
  • Robots WILL kill you.
    • LEDBlinky
Re: GGG Tron Handles to Standard Joystick?
« Reply #1 on: August 23, 2009, 09:57:12 am »
No, but I did convert a Happ Super to use a trigger stick from an old pc analog joystick. It worked ok but the spring wasn't quite strong enough so the stick felt very loose. Also, the trigger stick provides a lot more leverage so I was really concerned that the hollow shaft would bend or the base would just break under the extra stress. Eventually I replaced my home-grown stick with a Happ Heavy Duty 8-way - the base on that is built like a tank.
Robots will kill you.
Arcade Addiction
