Author Topic: exit any emulator with same key press??????  (Read 2548 times)
vanschlong
  • Last login:August 17, 2009, 04:48:38 pm
« on: August 10, 2009, 02:48:01 am »
Is there any way to exit any emu with the same key press? I use player 2 and right flipper to exit mame and would like to use this to exit all emu's. With hyperspin i used hyperlaunch which did the job, I thought that there might be a similar app to use with mala.
dungbeetle46
  • Last login:June 25, 2016, 07:27:47 pm
Re: exit any emulator with same key press??????
« Reply #1 on: August 10, 2009, 04:55:11 am »
you could use closemul
vanschlong
« Reply #2 on: August 10, 2009, 05:11:36 am »
I'll have a look see, cheers. ok got that, now i cant quite figure out how to use it, you put the closemul.exe in the same folder as the emu but how do you get it to work?
« Last Edit: August 10, 2009, 05:33:32 am by vanschlong »
dungbeetle46
« Reply #3 on: August 10, 2009, 08:55:28 pm »
depends what your right flipper button is as you need the ascii code.
player 2 is 50 so in Mala under other emus, Executable, lets say its Pinball.exe
you put c:\Path to your pinball\Closemul.exe 50 number of right flipper Pinball.exe
Henrik68000
  • Last login:December 12, 2010, 01:54:23 pm
« Reply #4 on: September 09, 2009, 06:07:01 pm »
Why not just use 'esc'? The emu's that cant respond to this button can be forced to to this by enable the mala close hook. I use the button 'Q' to close down mala altogether. I have 40 layouts/emus and all the one that dont have a build in esc  respond to the mala 'esc' hook for ending.
Henrik
« Last Edit: September 17, 2009, 04:18:25 pm by Henrik68000 »
