Author Topic: Multi-williams Defender "reverse" button question/joystick mod.  (Read 1711 times)
GaryMcT
  • Last login:September 24, 2014, 11:19:27 am
    • GaryMcT's arcade blog
What 8-way joysticks are easily modifiable such that you can put a button as close to the stick as they are on an original Defender machine with the two-way stick?  I've heard of people doing this, but I'm curious what sticks they use?
My blog on learning how to develop FPGA versions of arcade boards: http://garymct.blogspot.com
GaryMcT
Re: Multi-williams Defender "reverse" button question/joystick mod.
« Reply #1 on: July 29, 2009, 07:36:15 pm »
Found it in this thread!
http://forum.arcadecontrols.com/index.php?topic=82479.msg997476#msg997476
Modding a U360 to be usable with a Defender reverse button next to it looks pretty easy.  I'm starting to feel a single-player panel brewing. :)
Bender
« Reply #2 on: July 30, 2009, 01:52:05 pm »
actually the U360 would be easier (it's a regular JLW in that thread) because you don't have to worry about the microswiches
so theoretically you could put it even closer
polaris
  • veni vidi congai
« Reply #3 on: July 30, 2009, 01:56:44 pm »
i assume you can place a 360 in any orientation , and use the mapping.
that other thread requires cutting the plate im wondering if putting a u360 in the other orientation will remove the need for trimming the plate
GaryMcT
« Reply #4 on: July 30, 2009, 05:05:39 pm »
Excellent!
GaryMcT
« Reply #5 on: July 30, 2009, 05:06:03 pm »
I think it's still in the way in the other orientation, but I'll have a look at it soon.
polaris
  • veni vidi congai
« Reply #6 on: July 30, 2009, 05:13:30 pm »
cool, i dont have one yet so itll be nice to know :cheers:
Bender
« Reply #7 on: July 30, 2009, 07:54:25 pm »
either stick can be installed either vertically or horizontally
GaryMcT
« Reply #8 on: July 31, 2009, 02:39:17 pm »
Looks like you'd have to modify the mounting plate no matter which way the joystick is mounted.
