Author Topic: Jumpy sound problem in all games with Mame32  (Read 2218 times)
onespriggan
  • Last login:March 13, 2010, 06:11:42 pm
« on: July 19, 2009, 12:01:53 pm »
I just completed my CP and everything seems to run fine with the exception of the sound.  It works but seems to be kinda jumpy and just about all the games I play.  I am running Mame32 on a Dell Pentium 4 with 512 ram so I shouldn't have a memory problem.  Is there a sound setting in the program that I should be changing or should I use a different front end?
thanks
KDOG
  • Last login:September 18, 2020, 03:08:26 pm
Re: Jumpy sound problem in all games with Mame32
« Reply #1 on: July 19, 2009, 12:16:29 pm »
What version of mame 32 are you using? If it is the most recent version try rolling back to an older version of mame 32 like around 106.
mvsfan
  • Last login:May 26, 2016, 08:05:26 pm
« Reply #2 on: July 19, 2009, 05:26:19 pm »
speaking of mame32 versions, anyone know where i can find the .Cht file for 0.95?
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #3 on: July 19, 2009, 09:32:23 pm »
Grab the cheat file for an earlier version and you will have most bases covered. Cheat files were not released for each incremental version of MAME. Try here first.
onespriggan
« Reply #4 on: July 19, 2009, 11:19:52 pm »
I using release 124a.  Has there been a known problem with sound issues in these newer releases?
LeedsFan
« Reply #5 on: July 20, 2009, 01:42:41 am »
What refresh rate is your monitor set at? I've been having a similar problem and on searching around it seems the monitor was at fault. Basically the games played OK but I could definitely hear the sound being stuttery/jumpy in some titles.
The problem for me was that my monitor was set at 60Hz refresh rate. A lot of games were made to run on higher refresh rate screens, and this can cause the stuttery sound.
If you can set the refresh rate on your monitor higher then go for it. See if that helps. If you are stuck with a 60Hz monitor (like I was) then you can set "Frameskip 1" in mame.ini. Or set "Refreshspeed 1" in mame.ini. Only try one of these though, shouldn't need both.
They work kinda differently, but have the same effect. Refreshspeed divides the refresh rate of your monitor with the rate the game requires. It then slows the game down so it matches. It might only slow it by 1% and so you wouldn't notice. Frameskip just misses a frame every second or so and can help stop stuttery sound. But first thing to do is just raise the refresh rate of your monitor if possible.
I'm not an expert on stuff like this, but it worked for me. Your problem may not even be the same thing I had, but it sounds similar.
