Author Topic: wanting to turn a die hard cabinet into a multicade have a question  (Read 1073 times)
arcade1213
  • Last login:July 27, 2009, 12:08:27 pm
looking to get a 173-in-1 BabyStar Multigame Horizontal JAMMA PCB and
put it in a die hard cabinet will this work is Sega ST-V (JAMMA)
harness the same as a regular jamma harness or do i need some sort of
adapter,if i do need an adapter where could i get one thanks for your
time
arcade1213
Re: wanting to turn a die hard cabinet into a multicade have a question
« Reply #1 on: July 11, 2009, 06:33:16 am »
i was thinking that it should work but im not certain if the pinouts are the same on the harnesses
Kevin Mullins
    • Me on Myspace
« Reply #2 on: July 11, 2009, 07:34:22 am »
JAMMA is JAMMA is JAMMA   ;)
arcade1213
« Reply #3 on: July 11, 2009, 10:23:46 am »
awsome thanks for your answer.just a question that i had to ask to be shure
