Author Topic: RGB to VGA  (Read 2415 times)
gevauna
  • Last login:July 08, 2009, 07:02:59 pm
RGB to VGA
« on: July 08, 2009, 08:19:34 am »
I want to put a flat screen monitor into my 1995 virtual fighter 2 cabinet.  Is it possible  to use a cable adaptor to go from the three color wires (Red Blue Green) to a VGA port on a flat screen monitor using the already made cable or will the standard computer monitor still have issues converting the signal?
tekopaa
  • Last login:March 24, 2012, 11:19:53 am
Re: RGB to VGA
« Reply #1 on: July 08, 2009, 06:26:09 pm »
Use the search LUKE  ;D
search there are DVI-COMPONENT and VGA-COMPONENT Cables make sure that it will work with your Videocard. Also u can buy AGP/PCI card with Component output. That RED GREEN BLUE is component video output.
http://www2.pccables.com/images/01779.jpg
http://www.techpowerup.com/reviews/Sapphire/X1950_GT/images/contents.jpg
examples
« Last Edit: July 08, 2009, 06:27:48 pm by tekopaa »
gevauna
Re: RGB to VGA
« Reply #2 on: July 08, 2009, 06:47:10 pm »
Thank you for your reply.  I am really new to this stuff.  The monitor is out completely in the arcade cabinet and I don't have access to see what the computer is doing much less have a key board to access the computer.  How do I go about hooking up a keyboard to search for LUKE.  Sorry you have to dumb it down a bit for me.  First timer here and just getting my feet wet.
tekopaa
« Last Edit: July 09, 2009, 03:02:21 am by tekopaa »
gevauna
Re: RGB to VGA
« Reply #4 on: July 08, 2009, 07:02:59 pm »
Thanks.  I will check that out.
