Author Topic: The Effects Of Too Much Rock & Roll....  (Read 2195 times)
caesar
  • Last login:July 20, 2013, 09:00:50 pm
« on: May 31, 2009, 04:24:49 am »
Hello,
   Here's a question for the jukebox folks who have speakers mounted in the same cabinet as their PC.
Has the music's vibration (over a period of time) caused any problems for touchscreens, mobo's or HDD's for anyone?  :dunno
« Last Edit: May 31, 2009, 09:32:48 am by caesar »
Barry Barcrest
  • Last login:November 09, 2021, 09:54:17 am
  • Simple Plan
    • E-Touch Jukebox
Re: The Effects Of Too Much Rock & Roll....
« Reply #1 on: May 31, 2009, 08:57:33 am »
Not for me and i blast out Metal all the time. Mind you i don't have the speakers in the same cab.
caesar
« Reply #2 on: May 31, 2009, 09:40:22 am »
Thanks for the reply Barry...
As Barry goes, so does the PC Juke World.   :notworthy:
I considering cutting the bottom part (speaker enclosure) of my cabinet off.
Anybody else ???
digitaldj
« Reply #3 on: May 31, 2009, 10:08:21 pm »
I am one of the very few that has a full sound system in their juke which includes 2 15" bass speakers. I continually play it so I can hear it through the house and I haven't had any problems. I do have my hard drive rubber mounted with a cooler and makes a big difference. I also have a commercial audio amp that sheilds the hard drive from any magnetic fields.
caesar
« Reply #4 on: June 01, 2009, 02:14:45 am »
Hello,
What do you have for a monitor?  ???
I like the idea of rubber mounting or maybe even small coil spring supports for the HDD.
Wow ! 2x15" woofers  :applaud:,
Yeah...now I'm thinking I'm putting to much thought into this project.
I decided to go with a 40watt, 2.1 computer type speakers so the tuned port woofer is already enclosed & shielded in it's own cabinet.
« Last Edit: June 01, 2009, 02:19:20 am by caesar »
digitaldj
« Reply #5 on: June 01, 2009, 10:38:46 am »
Right now I am still using a 17" monitor but have a flat screen to install. I just gota get time to do it and make a new bezel around the monitor.
The bad thing about coil springs is there still the tranfer vibration, the best is rubber. This is what I am using:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118215 There are also other types available depending on you mounting situation.
You can see my juke at projects page under Art Deco Jukebox
