Author Topic: Craftsman power turn-on unit clipping  (Read 2277 times)
Ummon
  • Trade Count: (+13)
« on: May 22, 2009, 01:00:27 am »
Per forum mention, I picked up ones of http://www.sears.com/shc/s/p_10153_12605_00924031000P?keyword=craftsman+power+turn-on%5C
I've had it for about a year and a half, and I just opened it. The problem I'm having, is that with my candy cab connected to one of the accessory outlets, the turn-on unit starts clipping (making clicky sounds, and the monitor goes on and off) after a few seconds. Anyone have this problem or something?
Yo. Chocolate.
Stephen Hawking
arzoo
  • Last login:January 26, 2025, 08:51:53 am
  • Robots WILL kill you.
    • LEDBlinky
Re: Craftsman power turn-on unit clipping
« Reply #1 on: May 22, 2009, 08:18:36 am »
Never had any problems with mine. Seems like yours may be defective. Sears is usually pretty good about returns.
By the way - your link to the sears site is not working.
« Last Edit: May 22, 2009, 08:21:11 am by arzoo »
Robots will kill you.
Arcade Addiction
severdhed
  • RIP Dinosaur Hippo
« Reply #2 on: May 22, 2009, 01:40:42 pm »
mine has been working for years now...sounds defective
mrclean
  • Last login:August 10, 2022, 08:30:36 am
  • World Record Holder for Gun Smoke Dedicated & MAME
    • Guscade
« Reply #3 on: May 22, 2009, 03:12:54 pm »
2,370,650 Gun.Smoke
Kevin Mullins
    • Me on Myspace
« Reply #4 on: May 22, 2009, 04:24:25 pm »
What do you have plugged into the "Power Tool" outlet ?
Maybe it's not pulling enough current to trigger the "Accessory" outlets on properly.
Seems like I read that some of the other similar units had an adjustable sensitivity, not sure if these do or not.
severdhed
« Reply #5 on: May 22, 2009, 04:30:48 pm »
yeah, i read that wrong...
what do you have plugged into the main outlet that you are turning on to trigger the rest of it?
Ummon
« Reply #6 on: May 22, 2009, 07:05:22 pm »
PC is main, cabinet is accessory. I thought of that - maybe I should switch them? I just didn't want to expose the computer to that clipping if I could help it.
Yo. Chocolate.
Stephen Hawking
severdhed
« Reply #7 on: May 22, 2009, 08:49:21 pm »
i'm not following i guess.  when you say the cabinet is on an accessory port..i'm assuming that is monitor, speakers and lights?
does the PC stay running properly during this? what happens if you plug a lamp or something else in, does it flicker?
what happens if you use a lamp/something else in the master port, instead of the PC?
Kevin Mullins
    • Me on Myspace
« Reply #8 on: May 22, 2009, 10:39:51 pm »
That would be my next step also...... plug a drill or something outlet you know pulls more current than the PC into the "Power Tool" outlet and see if it still acts up.
(leave the cabinet/monitor connected as is)
Ummon
« Reply #9 on: May 23, 2009, 05:18:56 pm »
Oh. You mean, like, TROUBLESHOOT IT. Heheheheeh, I'll get right on that.
Yo. Chocolate.
Stephen Hawking
jasonbar
  • Dr. Inferno
    • The Infernolab
« Reply #10 on: May 23, 2009, 11:44:00 pm »
+1 for that Sears outlet working just fine for about a year or so (unlike the SmartStrip, which never worked well for me...).
-Jason
Ummon
« Reply #11 on: May 24, 2009, 12:29:54 am »
Hmm. Seems computers just don't pull enough to make it go.
Yo. Chocolate.
Stephen Hawking
jasonbar
  • Dr. Inferno
    • The Infernolab
« Reply #12 on: May 24, 2009, 03:38:41 am »
Maybe you should use an inefficient old computer w/ a noisy fan like me.  It'll draw enough current to trigger the outlet!   ;D
-Jason
TOK
  • The Game Always Wins
« Reply #13 on: May 24, 2009, 05:33:21 am »
I'm using these on 2 machines. PC on the trigger outlet, speakers, monitor and lighting on the slave, and it has always worked fine.
Encryptor
  • Trade Count: (+34)
« Reply #14 on: May 24, 2009, 06:30:32 am »
I'm using one on mine as well and it works fine.
Encryptor
