Author Topic: ArcadeVGA + TV + Lightguns  (Read 916 times)
freppa
  • Last login:September 30, 2004, 08:45:31 am
« on: July 03, 2003, 07:36:03 am »
This might be a stupid question, but I have to ask.
From what I can tell you can wire up the ArcadeVGA to a TV using RGB-inputs on the SCART, and the results are supposed to be great.
My question is: If you do this and want to get some Act-Labs lightguns for it, What kind should you get? The PC or the TV-version?
My guess would be the PC-version, but I'm not sure. Anyone running this setup???
/Freppa
brandon
  • Last login:June 08, 2025, 02:40:01 pm
  • I <3 arcade games.
Re:ArcadeVGA + TV + Lightguns
« Reply #1 on: July 03, 2003, 06:07:06 pm »
I found this on the Act-Labs FAQ for the USB light gun...
Q: Which USB Light Gun will work with my Arcade Monitor?
A: The PC USB Light Gun will work with an Arcade Monitor as long as you have a JPAC Arcade VGA card available from www.ultimarc.com
I dont know anything about SCART TV but since it connects to RGB the same as an arcade monitor then I would assume it would work the same so you would need the PC version.  I guess you could email Act-Labs just to confirm this..
GamingGreg
  • Last login:August 05, 2018, 06:04:30 pm
« Reply #2 on: July 03, 2003, 07:40:27 pm »
I had asked Act-Labs about this very thing and they told me I'd have to use the USB VGA (not TV) version.   If you want to use two guns this would be a problem right now as it only officially supports one gun.  However I have heard you can use two USB VGA guns with the Analog+ version of MAME. (see this thread http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=8512;start=msg65920#msg65920)
Also Act-Labs has said that a dual (two player) version of the VGA gun is scheduled to come out towards the end of this year.
