Author Topic: Can I -ror an entire gamelist or do I have to do each one individually?  (Read 2353 times)
I posted this in the Software forum and someone suggested I post here...
I'm trying to config a 3 sided cocktail - I have some gamelists made in MaLa for vertical games that I want rotated 90 degrees - is there a simple way to do this?  I don't want to rotate the horizontal games, obviously.  Thanks!
James, there is probably a easier and better way to do it, but I have been working on a plugin to work with my mrotate2 program.
You could test it on what you want, just need a dummy mrotate2.exe file which I can send you that would basically do nothing when called.
Check out this post:
http://forum.arcadecontrols.com/index.php?topic=91842.0
You could test it, if it works for you, I can probably trim down startcom to do only what you need done.
SGT
  • Last login:May 31, 2025, 10:10:32 pm
I may have misunderstood the problem, but Mala's mame configuration has conditional command lines.  You could add the -ror for only vertical games.  Of course this is only for Mame games.
« Last Edit: May 03, 2009, 07:57:37 pm by SGT »
This seems to have worked.  Whenever a vertical game is launched it displays properly.  Now I've got to figure out how to make MaLa itself rotate to vertical (-ror) when the end controls are being used but stay horizontal when the long CP is being used (and create separate gamelists).  I have a feeling I'm going to need an iPac4 or something since I have the P1 and P2 controls going to the same nodes on my iPac2.  I have a lot of software tweaking to do on this cab!
Thanks - I still haven't given up on the rotating monitor for a stand-up I'm building.  I hope to get to it before the summer is over but I still have a DK to finish up as well as the juke.  I have a feeling once I get into the whole rotating cab thing I'm going to be obsessed until I finish.  I'm just happy that a bunch of you guys have it pretty much figured out!  So many projects!!!   :cheers:
« Last Edit: May 05, 2009, 09:55:14 am by javeryh »
