Author Topic: Oscar Spinner Space Requirements ?  (Read 2260 times)
webby99
« on: March 03, 2002, 04:45:44 pm »
Hi,
My control panel is really low on space but I'd like to add an oscar spinner. Does anybody know how much space is required under the panel for the spinner mechanism. Id like fairly exact sizes specs if thats possible . The top isn't a problem because its a metal panel so only the spinner nob will be seen.
Cheers
Webby
OSCAR
    • Oscar Controls
Re: Oscar Spinner Space Requirements ?
« Reply #1 on: March 03, 2002, 05:06:16 pm »
You should plan on a 2.5" x2.5" area under your control panel for the spinner.  The actual dimensions are slightly smaller, but 2.5" x 2.5" will give you adequate clearance to your other controls.
--OSCAR
