Author Topic: Quit button for Sega genesis emulator  (Read 5979 times)
  • Last login:January 25, 2026, 10:26:13 pm
« on: April 07, 2009, 07:07:41 am »
Ive been playing around with the gen emulator.
Is there anyway to assign the escape button to quit the emulator?
I have to left click with the mouse then choose "quit" from the emuls menu bar.
It would be neat to add this to my cab, but I want to be able to quit the emul just like I do mame.
Sorry if this is the wrong forum to post this.
markc74
  • Flipping out
Re: Quit button for Sega genesis emulator
« Reply #1 on: April 07, 2009, 07:38:34 am »
You need to use a wrapper to launch the emulator.  There's one called closemul (http://clusters.cjb.net/closemul/) which should help.  I havent used it for a while but I think it's straightforward enough to setup
Ginsu Victim
  • Comanche, OK -- USA
« Reply #2 on: April 07, 2009, 08:16:45 am »
Which genesis emulator? KegaFusion allows me to escape out.
« Reply #3 on: April 07, 2009, 07:09:19 pm »
I have Sega Gens V 2.14 Souvenir.
kegger
  • Last login:April 10, 2011, 10:59:14 am
  • There are no unsingable songs....
« Reply #4 on: April 07, 2009, 08:26:19 pm »
Here is a link to GensFE 2.11 that has been modified to close with escape key
http://www.localarcade.com/screenshotarchive/downloads_emus.htm
Also at bottom of page there is Gens 2.11 that works with Arcade Vga
« Last Edit: April 07, 2009, 08:28:41 pm by kegger »
« Reply #5 on: April 08, 2009, 07:16:35 pm »
I downloaded the GensFE 2.11 but when I try to unzip it, it says it is corrupt.
Tried downloading twice, same results.
reko19
  • Last login:July 16, 2025, 10:06:10 am
« Reply #6 on: April 10, 2009, 12:53:56 pm »
try using Fusion 351 emulator, works well for me
« Last Edit: April 10, 2009, 12:55:57 pm by reko19 »
kegger
« Reply #7 on: April 13, 2009, 09:24:27 am »
Try the gens 2.11 at bottom of page and see how you make out.
I'm out of town now so I can't try it.
All those emulators listed close with escape key.
kegger
« Reply #8 on: April 13, 2009, 09:46:00 am »
Sorry scratch that idea too as it doesn't work either.
I will see if I have it at home when I get back into town.
« Reply #9 on: April 19, 2009, 07:23:10 pm »
Bumped for update.
I found where mala can be set to exit the emulator.
(hotkey option in mala, I assigned it to be escape.)
Mala is a dang good front end!
What other emulators do you guys have on your cabs?
I downloaded and tested NES, but it shows the windows menu bar and taskbar.
