Author Topic: MAME Intro Vids is returning  (Read 31821 times)
cdbrown
  • Last login:October 16, 2017, 09:52:03 pm
  • Bowowow
« on: March 25, 2009, 01:27:05 am »
Well folks, after a number of years in hiatus NIVO and I have been talking recently about updating the intro vids we created all those years ago.  We had produced short intro clips of parent roms for mame version 0.106.  http://forum.arcadecontrols.com/index.php?topic=45467
After this mame revision various things happened to the core and xml outputs which subsequently broke the various programs provided by Cakemeister and Silver.  I think these things are now working so am going to tackle the update.
For anyone that actually cares NIVO is currently running each and every parent game in 130u1 to determine if there's attract sound and if there needs to be a dip switch changed or in game setting to enable it.  I'm going through all the 0.106 vids to check for sound, sound quality and general picture quality.  Those that are dodgy will get redone.
I already have the list of all the games added between the 2 revisions so once NIVO's check is done I can run those.  It's taking a little bit of time to get batch files working right - need to run mame with necessary settings, capture the mng using -mngwrite, capture the sound using -wavwrite, then convert the mng to avi (using mng2avi), combine it with the wav (using vdub) and then end up with a vid which will need manual editing to trim and resize.
These vids seemed to be quite popular in 05/06 when they were first produced so I'm wondering if anyone is actually using them in their front end.  Note that these aren't the same as what Circo has produced - his is at a higher resolution and is of him playing the game.  These are generally very short clips taken from the attract sequence of a game.  So for those that are using them do you have any comments regarding the vids in general or particular games (too short, doesn't show the game, etc) and we can look at doing something about them.
Cheers
-cdbrown
headkaze
  • 0x2b|~0x2b?
Re: MAME Intro Vids is returning
« Reply #1 on: March 25, 2009, 09:42:40 am »
Most people are using the EmuMovies collection these days I believe. These are ingame videos with some gameplay and I think people prefer that. It took Circo a long time to play a bit of each game to create them and there are high quality versions available. Also HyperSpin requires the videos to be in flv format and Circo has already created an flv collection for that. Perhaps you could contact Circo and offer to help him do some updates?
gonzo90017
« Reply #2 on: March 25, 2009, 01:27:28 pm »
I'm glad you're going to be working on them again. I looked for your videos but couldn't find them anywhere!
Circo
  • Last login:May 11, 2020, 03:27:51 am
  • Still using screenshots? Try EmuMovies instead.
    • EmuMovies
« Reply #3 on: March 25, 2009, 07:32:25 pm »
CDBrowns are much smaller, we used to help distribute them until our official Mame set was released.  The videos talked about in this thread are very good if you have limited hard drive space or an older system.  They are also the exact attract scenes in the games wheras the EmuMovies set has a lot of actual gameplay because I wanted to make sure that there was sound in the previews and I could see what the game was like.  But they are not the authentic attract modes like cdbrown's were.
EmuMovies
HiQ 640x480 - 3961 files - 22GB
SQ 320x240 - 3961 files - 8.54GB
CDBrowns were:
XXX x 260 (native aspect) - 2907 files - 3.44GB
There is room for both I believe, and I fully support his project :)
« Last Edit: March 26, 2009, 05:31:23 am by Circo »
My Websites
cdbrown
  • Bowowow
« Reply #4 on: March 25, 2009, 08:12:32 pm »
Circo's set is great if you are using a screen with a decent resolution.  My set is better suited to tv screens or old arcade monitors with lower resolutions.  We had all vids set to a max res of 256x256 but maintained the aspect ratio.  The fit perfectly into a 800x600 res layout for mamewah - which is just what I need for my setup.  Also as Circo mentioned they are much smaller - 2907 vids are 3.44GB where Circo's are larger.  For those with better resolutions or want a higher quality clip then Circo's will suit you well.
Gonzo - the vids up to 106 are still available online, check the link in my first post.  As for the rest well that's just going to take some time.
The initial batch file set up is working such that it get's mame to produce the mng and wav and put them both in a specified folder before moving onto the next game.  I've got mng2avi to turn the mng into a series of pngs, but then the process stops due to vdub looking for a script file which doesn't exist and not entirely sure what is supposed to be creating it.
NIVO
« Reply #5 on: March 25, 2009, 08:23:54 pm »
id also like to pay respects to circo's set, a well done project. I'd like to echo cdbrowns sentiments. No harm for having options, besides its something we WANT to do and making use of our spare time when possible. We are moving forward, slow and steady. We may even throw up a sample here and there as we move along. Stay tuned!
Circo
    • EmuMovies
« Reply #6 on: March 26, 2009, 05:19:45 am »
I hope you don't mind if I just point out that the EmuMovies SQ videos work just fine at the lower resolutions :) If your preview box is less than 320x240 the front end scales it down :D
I wanted to avoid any confusion.
Ok back to the topic my apologies ;)
« Last Edit: March 26, 2009, 05:32:38 am by Circo »
My Websites
Cakemeister
  • Last login:May 31, 2024, 06:23:16 pm
« Reply #7 on: March 26, 2009, 02:26:51 pm »
Hello,
If the mng2avi program does not detect an attract loop, then no .vdb file is written and no .avi file is produced.
I suggest letting the batch process run for as many movies are created, then progressively lengthening the -str parameter to MAME.
My batch.bat file:
@if "%1"=="" goto badparm
@if "%2"=="" goto badparm
@goto goodparms
:badparm
@echo This batch file requires 2 parmaeters:
@echo 1) rom name
@echo 2) resolution
@echo Please reread the directions on how to use this utility!
@pause
@goto end
:goodparms
@if not exist pngs mkdir pngs
@if not exist movies mkdir movies
@if exist movies\%1.avi goto end
@rem for reruns
@if exist snap\%1.mng goto norungame
@if exist nvram\%1.nv goto rungame
@mame %1 -window -resolution %2 -nothrottle -str 1 -nouse_bezels -nouse_backdrops
:rungame
time /T
mame %1 -window -mngwrite %1.mng -resolution %2 -wavwrite %1.wav -str 60 -nouse_backdrops -nouse_bezels
:norungame
@if not exist %1.wav goto nosound
mng2avi -log snap\%1.mng -wav_name %1.wav
goto finish
:nosound
:finish
@call vdb output.vdb movies\%1.avi
@del snap\%1.mng
@del %1.wav
@del /q output.vdb
@rem @move png.avi movies
@rem @ren movies\png.avi %1.avi
:end
My vdb.bat file:
@virtualdub\vdub /s"%1" /x
@if exist %2 del /q %2
@move output.avi %2
Old, but not obsolete.
TelcoLou
  • Four score and seven years ago our fathers brought forth on this continent, a new nation
  • Last login:October 14, 2010, 01:28:19 am
  • Playing video games since 1977
« Reply #8 on: March 26, 2009, 10:54:11 pm »
I've never used them, but thinking about it, I'd LOVE to see authentic attract screens for each game as they're selected.
Count me in as VERY interested!
So a leper walks into a bar and as he gets his beer, a finger falls off. The bartender who is serving him turns and pukes all over the place. The leper, feeling bad, says, "Was it my finger falling off?" The bartender turns to him and says, "No, it's the guy dipping chips into your back."
cdbrown
  • Bowowow
« Reply #9 on: March 27, 2009, 01:08:51 am »
Cheers for that Cakemeister.  I was originally just fooling around with it using a low -str so it would be a quick process.  I also tried to turn off the loop detect option in hope that it would just create the vid what ever length I had set -str to be, but I guess this isn't the case.
The batch is pretty much the same as mine except I've modified the older version so there's still references to max frames and such which doesn't get used.
NIVO
« Reply #10 on: April 02, 2009, 03:14:30 am »
Just a quick little update: about 95% through the parent rom list by hand, so it has taken quite alot of time. Good news is we are almost ready for phase 2.  :cheers:
Game On!
cdbrown
  • Bowowow
« Reply #11 on: April 02, 2009, 09:16:11 pm »
Yep I've reviewed all the previous vids to check out if they had sound or not.  We've nearly got a complete list of all parents which show if the game has attract sound and whether or not you need to go into the service menu to enable or increase the volume.  For those with the attract in the dips these are always enabled - but doesn't necessarily mean they work.
Also have the batch process setup to auto run the game, record the mng and wav, split the mng into pngs and then detect the loop and finally run vdub to combine the wav and mng into an avi using lame mp3 and xvid codecs.  However I'm struggling in getting the process to work with my own xvid settings.  Previously Silver produced a nice little installer file which had a pretty front end to input the choices - I can't seem to get my hands on it so aren't able to duplicate the vcodec.dat file.  Using -movievideo 4 allows me to use the vcodec.dat along with the standard commands of mng2avi, so I have been able to apply the smart resize filter using this in vcodec.dat
VirtualDub.video.filters.Clear();
VirtualDub.video.filters.Add("smart resize (1.1)");
VirtualDub.video.filters.instance[0].Config(256,224,0,2,256,224,0x000000,"1 1 1 2 256 256 100 0 0 1 1 4 4 2 2");
I have not been able to reduce the fps from the standard 29 to 15 which we previously had.  The code for this is
VirtualDub.video.SetFrameRate(66667,1);
But mng2avi produced this in the vdb file
VirtualDub.video.SetFrameRate(16949,1);
VirtualDub.video.SetTargetFrameRate(30000,1001);
Cakemeister - is there a way to make mng2avi not spit out it's own FrameRate and use the one that's in the vcodec.dat?
Cakemeister
« Reply #12 on: April 03, 2009, 11:27:35 am »
Okay, I made the requested change.
The updated zip file should be here.
retrometro
  • Last login:May 24, 2024, 09:11:44 pm
    • Arcade, mame, retro... and the gp2x.
« Reply #13 on: April 09, 2009, 06:46:38 pm »
It would be fantastic if this much attention can be paid to other console sets there videos aren't as plentiful.  ...like dreamcast, n64, etc.
-------- gp2x and retro... play it forever! ------------------------
http://www.youtube.com/view_play_list?p=0EE573E86D5A86E0
lingpanda
  • Last login:May 16, 2010, 01:43:52 pm
« Reply #14 on: April 11, 2009, 06:43:08 am »
Looking forward to this! +1
cdbrown
  • Bowowow
« Reply #15 on: April 14, 2009, 09:00:31 pm »
Been slowly progressing with this, nearly done the full review of all the games to check for sound and which ones require us to go in and change the ingame settings for sound.  Also allowed us to get a proper list of which games actually work.
Currently fiddling with virtualdub to get the right settings so we can match the old vids but currently struggling getting the audio part right.
So far have got the smart resize filter sorted so it will resize the vid to a max 256x256 resolution while maintaining aspect ratio.  This is done ensuring the final res is a multiple of 4 and using bicubic filter mode.  The frames per sec have been chopped to be 15fps and the xvid is set to quantizer 3.  This gives a very close bit rate as the original for the video part.  Using the Lame MP3 codec, I've not been able to match the bitrate we had in the original vids, sometimes it makes the video length 4 times the source (due to the fps being 1/4) and sometimes it works.  I have a feeling it may be just those games that don't have sound, but an wav file is still captured, so I may have to edit the batch process to delete the wav file before it opens vdub.
NIVO has also been working through the u1, u2, u3 updates as they come out so will make things easy to keep up to date.
cdbrown
  • Bowowow
« Reply #16 on: April 17, 2009, 04:51:23 am »
cakemeister - what are the different -movieaudio options?  I think 1 is the default mp3 setting, 4 disables, is there one that allows me to use the settings in vcodec.dat?
Cakemeister
« Reply #17 on: April 17, 2009, 11:56:56 am »
-movieaudio 2 uses acodec.dat.
cdbrown
  • Bowowow
« Reply #18 on: April 20, 2009, 08:55:02 pm »
Thanks Cakemeister that was it.
After much stuffing around with mng2avi the ini settings, virtual dub and the various outputs it created, it looks like I've finally got the correct vcodec.dat and acodec.dat settings to create the vids like before.  The audio bitrate and every thing is the same, but the video bitrate is slightly increased giving a better picture with only a small increase in file size.  So production on the videos will commence shortly.  No estimate on timeframe though as I currently don't have a lot of time to dedicate to the manual editing of each video before release.
cdbrown
  • Bowowow
« Reply #19 on: May 01, 2009, 04:06:58 am »
Well looks like there is a bit of a problem.
It would seem that the resolution for a number of games isn't quite right.  So when mngwrite or aviwrite is used it will produce a video set to the resolution that mame reports in game.  However when using the -verbose tage, the actual resolution being displayed on screen is different.
For exampe ar_bowl (SportTime Bowling) the resolution according to mame is 671x216 which  means the game display is about 3 times as wide as it is tall.  With keepaspect (which is supposed to maintain the aspect ratio of the game) it produces a res of 671x503.  So it looks good on the screen while the game is running, but the video produced is the wide and short.  It would seem there are quite a few like this so it's going to take some time to actually go through and find out which ones are grossly wrong (some are just a few pixels different).
holdennut
  • Last login:January 16, 2015, 04:53:06 am
  • Aussie lowboy cab finished!
    • Australian Cocktail Pac-Man Project
« Reply #20 on: May 10, 2009, 09:34:37 pm »
A big thumbs up from me.  :cheers:
cboy
  • Last login:October 07, 2012, 02:09:29 am
« Reply #21 on: May 10, 2009, 10:14:49 pm »
I cant wait for this!  :cheers:
cdbrown
  • Bowowow
« Reply #22 on: May 11, 2009, 02:53:50 am »
Am continuing with producing the vids and noting down which ones are clearly coming out with the wrong resolution so that I can go back to the later and try to get vdub to change the aspect before it resizes.  Some of the vids are coming out horribly distorted because mame is reporting the incorrect resolution.
FrizzleFried
    • Idaho Garagecade
« Reply #23 on: May 20, 2009, 02:56:36 pm »
How does one produce vids with hardware that changes resolutions?   I tried making a video of a GNET game and it comes out at 25% the window size...and REAL SLOW.
NIVO
« Reply #24 on: May 20, 2009, 10:57:04 pm »
those are some of the current issues we are having as well Frizz. Waiting to see what future revisions of mame do first and make sure its not on our end(unlikely).
cdbrown
  • Bowowow
« Reply #25 on: May 25, 2009, 11:39:41 pm »
Problems arise due to the resolution change of some games - mainly the screen test pattern is a different res to the actual game and aviwrite can't handle it.  This has been an issue for quite a while and we just can't capture the video of certain games.  When using the mng automated process I've got set up, the prog checks the mng for a loop, but due to the res change it falls over and just moves to the next clip.
I have read that the only real way to get a vid is to get the game going and then hit SHIFT+F12 to start capturing an mng.  Unfortunately there won't be any audio.  If you were that interested you could put -aviwrite in the command line and then try and sync up the video to the audio afterwards.  Not tried either procedure yet.
danfman
  • Last login:November 14, 2009, 10:26:45 pm
« Reply #26 on: July 15, 2009, 10:02:41 pm »
How are things going cd?
"It depends on how you define alone…" –Bill Clinton
cdbrown
  • Bowowow
« Reply #27 on: July 20, 2009, 12:32:01 am »
Not done anything on this for the last month or so - work has been getting in the way of trying to work around this resolution problem.  keepaspect displays things nicely on screen, but the internal resolutions mame has seems to display things stretched either vertically or horizontally and that is what is being output when recording an avi from within mame or the mng.  My auto resize that I run in vdub will need to be changed some how so that I input my own h and v settings.  All manual stuff and I'll need to know the mame resolution, the keep aspect res and then the calculate the resize resolution.
GaryMcT
  • Last login:September 24, 2014, 11:19:27 am
    • GaryMcT's arcade blog
« Reply #28 on: July 20, 2009, 09:11:10 pm »
What's a good example game that causes problem?  Is Tekken a good example?  What are your command-line options when you are generating the movies?  I might be able to have a quick look at workarounds in the code to make it generate all the frames at the same resolution.
My blog on learning how to develop FPGA versions of arcade boards: http://garymct.blogspot.com
cdbrown
  • Bowowow
« Reply #29 on: July 21, 2009, 04:50:30 am »
From my post above
It's all in a batch file but here's the main line for mame to run and export the mng
mamepp %1 -mngwrite %1.mng -wavwrite %1.wav -str 240
ryantheleach
  • Last login:October 17, 2013, 01:44:17 pm
    • My Personal Blog
« Reply #30 on: October 24, 2009, 09:23:39 pm »
dont know if this will work but headkaze said this a while back, he may be able to help.
Another thing I would appreciate a test of is setting the switchres to 1 which will change the res for each game. Now CPW detects a video mode change and then has a delay (called "Display Change Delay" in the Display Options) which is triggered, then after the delay it will re-adjust the windows to the new resolution.
this was in regards to his control panel wizard, but maybe he has some code he cans hare o solve your problem?
Henrik68000
  • Last login:December 12, 2010, 01:54:23 pm
« Reply #31 on: September 27, 2010, 07:28:55 am »
I imbrace your initative. I use circo's video right now but would rater have the videos og the games presentation the Vivo does. Make them not too short. Sound; i dont need it.
Maybe you could after doing the Mame's  do some of the ones Circo have not done. Intllivision , Vectrex, Bally Astrocade, Sega Dreamcast, the list goes on..
Henrik
« Last Edit: September 27, 2010, 07:31:12 am by Henrik68000 »
Circo
    • EmuMovies
« Reply #32 on: September 30, 2010, 06:52:24 am »
Intellivision, vectrex, bally astrocade and Sega Dreamcast all have video sets available at emumovies :)  Dreamcast is still a WIP set but is over 90% complete.
My Websites
cdbrown
  • Bowowow
« Reply #33 on: January 03, 2011, 09:29:15 pm »
Well it's a new year and I might as well try and pick this up again.  I'll try and run a few of the games that are missing from the original sets and see how they go.  If I still end up with the aspect problem I may just provide an update of those that look good and leave the others till a later date.
Is there still interest in the mame vids or will I be wasting my time?
cdbrown
  • Bowowow
« Reply #34 on: January 04, 2011, 10:15:24 pm »
I've done a little bit of looking into how much work is involved.  By using -listfull and -listclones (why they don't have -listparents I don't know) from the latest mame0141 there is 4611 parent games (out of 9122 games).  The previous set of vids released on mame0106 had a total parent list of 3316 parents with 2907 vids (12% games not working).  Assuming something similar there should be just over 4000 games.
I can't remember how to produce the list of roms and their resolution - any ideas?  -listxml has way to much information in there.
cdbrown
  • Bowowow
« Reply #35 on: January 05, 2011, 08:49:40 pm »
I've got listgen up and running so have a nice list of all the parents and their resolution.  Have also compiled it with the previous 0106 vid release to prevent any doubling up, now it's a matter of time to do some batch runs on the missing games and see what pans out.  So glad I found the batch and ini files from before.
georget1111
  • Last login:January 10, 2011, 10:31:43 am
« Reply #36 on: January 06, 2011, 08:37:43 am »
Wow, that sounds like a lot of work, but it's great to have all of these intro videos created and archived. I know your 0106 vid release is on [romsite name redacted] as 1 large download, but if I only wanted a handful of the classics like Pac-Man, Donky Kong, Galaga etc... are they hosted anywhere? I looked at Circo's website but his videos are "in game play" videos. I'm using 3DArcade as my front end and would love to have the original intro demos displayed on the screens. I did attempt to make some myself with Fraps, Screen Recorder and VirtualDub, but my results were not very good.
« Last Edit: February 04, 2015, 11:23:03 pm by PL1 »
cdbrown
  • Bowowow
« Reply #37 on: January 06, 2011, 08:44:28 am »
They aren't available in separate packs as it's too hard to manage.  However if you download the torrent file you can then enter into the file structure and choose only the vids you want, only the parents have been captured so you just need to look for that file name.  Unselect all the others you don't want.  Can be time consuming to do but a lot less time consuming than making the vids.
Glad someone wants to/is using them
georget1111
« Reply #38 on: January 06, 2011, 09:00:26 am »
I understand. Everyone wants something different. In the 80's I use to fix the classic arcade machines. I love having MAME so I can relive the good old days. Walking around my virtual 3DArcade with the intro videos running is a real blast. I have never done a torrent download but I will figure it out. Good luck with the update project. There are a lot of people that treasure these videos.
George
cdbrown
  • Bowowow
« Reply #39 on: January 06, 2011, 08:19:08 pm »
There seems to be a change in the video output in mame as I now see there's an option to use standard aspect or pixel aspect.  I'm guessing this is due to people having either original arcade monitors and others using tv/pc monitors.
The whole video problems may not be such an issue anymore if I can get mame to output the mng file in standard aspect and with -keepaspect enabled.  I did produce over 100 vids both new and updates during the last attempt at updating the set so I've begun going through them noting the output res, chopped length of vid, if there's sound and if it actually looks right.
So far most have looked ok but games like ar_airh (and the rest of ar_ games) have a very strange pixel aspect, so when running the game without the -keepaspect enabled it's stretched horizontally regardless of the video options in the game.  When running with -keepaspect enabled and the standard aspect selected in the video section of the menu it looks good, switch it to pixel aspect and you'll see the type of video that is being produced.
I had intended to try and review some new vids today as I had a batch process setup and running last night, but when I checked this morning nothing had been produced due to an permission access violation.  Damn comodo was preventing the batch file from running mng2avi for each game so no idea how long it sat there trying to run the program before aborting and moving to the next one.  It's been fixed now.  I have the process running so hopefully it'll get through some games today - doing #-B for games that are new or now working in 141 that weren't in 106.
