Author Topic: Split Screen  (Read 1787 times)
IG-88
Split Screen
« on: March 21, 2009, 10:02:37 pm »
How the heck did this guy split the screen in this video? Anybody know?
http://tinyurl.com/chrp4h
-HarumaN
severdhed
  • Last login:November 08, 2025, 10:49:16 pm
  • RIP Dinosaur Hippo
Re: Split Screen
« Reply #1 on: March 21, 2009, 10:51:29 pm »
that is done on a per game basis.  that is vs super mario...  if you hit tab, go to video options, and select Coctail, it will display that way.
IG-88
Re: Split Screen
« Reply #2 on: March 22, 2009, 08:22:55 am »
I'll be damned. I never tried that. So if you have dual monitors like a .vs setup would you run 2 vid cards or how do you do that?
-HarumaN
Ginsu Victim
  • Comanche, OK -- USA
Re: Split Screen
« Reply #3 on: March 22, 2009, 11:00:19 am »
It's single monitor. It's a workaround for games that don't have cocktail flipping.
severdhed
Re: Split Screen
« Reply #4 on: March 22, 2009, 12:44:37 pm »
in your mame.ini file, there is a setting for the number of monitors.  just set it to 2 and it will display the same thing on both screens for most games..or if the original game had more than one monitor, it will span or do whatever it was supposed to. (for instance if it is set to 2, if you play xmen, it spans the screen across both)
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: Split Screen
« Reply #5 on: March 23, 2009, 03:56:11 pm »
Mame has a special layout for doing this.  You can change it in the mame.ini (or game specific ini files), or from the in game video options menu.
For mame.ini:
view                      cocktail
For in game:
Press tab, select Video Options, select Cocktail.
It's been in mame for a while, soon after the 0.106-0.107 video changes (which made it possible).
Robin
Knowledge is Power
IG-88
Re: Split Screen
« Reply #6 on: March 23, 2009, 06:37:07 pm »
I figured that out late last nite. I haven't used anything newer than v.75. Guess it's time to update.  :P Glad to see that it has an option to remap the esc key too. Very nice.
-HarumaN
