February 14, 2026, 08:30:45 pm
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon
through our link. Thank you!
Main
Audio/Jukebox/MP3 Forum
rowe r 82 jukebox? record playing slow
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: rowe r 82 jukebox? record playing slow (Read 8081 times)
flathead31coupe
Trade Count:
0
Jr. Member
Offline
Last login:March 08, 2009, 08:38:57 am
on:
February 28, 2009, 12:35:34 pm »
iam working on a r-82 rowe, the records play just alittle slow, any advice on the fix
Logged
Ken Layton
Guru
Trade Count:
+1
Full Member
Offline
Last login:October 12, 2021, 12:25:59 am
Technician
Re: rowe r 82 jukebox? record playing slow
Reply #1 on:
February 28, 2009, 01:22:09 pm »
Clean the turntable motor pulley, the outside of the turntable surface where the belt touches, and the belt itself. This machine is old enough now that you probably should replace the turntable belt. It has probably stretched and is slipping.
Logged
flathead31coupe
Trade Count:
0
Jr. Member
Offline
Reply #2 on:
February 28, 2009, 04:09:36 pm »
this unit has no belt, it has a motor with a shaft that sticks up, and a little rubber wheel that runs against the shaft and touches the turntable, wandering if the rubber wheel should be hard or softer could be slipping
Logged
Ken Layton
Guru
Trade Count:
+1
Full Member
Offline
Technician
Reply #3 on:
February 28, 2009, 09:36:32 pm »
Could be any (or all) of the below:
The turntable motor mounting grommets are shot (compressed/dried out) allowing the motor shaft to sit cockeyed to the idler wheel.
Idler wheel rubber surface is worn too far allowing slippage.
Inside rim of turntable is glazed over and needs to be cleaned with laquer thinner.
Turntable motor bearings need oil.
Logged
flathead31coupe
Trade Count:
0
Jr. Member
Offline
Reply #4 on:
February 28, 2009, 11:41:55 pm »
where is the best place to get replacement parts?
Logged
Ken Layton
Guru
Trade Count:
+1
Full Member
Offline
Technician
Reply #5 on:
March 01, 2009, 12:32:58 am »
www.victoryglass.com
for all parts and manuals.
Logged
ami-man
Trade Count:
0
Full Member
Offline
Last login:July 19, 2020, 01:22:45 pm
Reply #6 on:
March 02, 2009, 10:50:12 am »
Hi,
Ken is correct if you are in the USA then Victory Glass is your best bet.
If you are in the UK then contact myself or
www.jukeboxparts.co.uk
With regards to the cleaning of the parts my advice is always use soap and water to get rid of the gease and oil (do not use on motors or electrics), any spays or cleaners always causes more trouble in the long run. If I was doing a clean up job in a pub I would ask for a shot of gin to use for the cleaning purposes.
Take the motor apart and check for wear, if none is found clean out the bottom bearing, reassemble and lubricate as per the manual (very sparingly)
Regards
Alan Hood
ami-man
UK
Logged
flathead31coupe
Trade Count:
0
Jr. Member
Offline
Reply #7 on:
March 02, 2009, 12:43:12 pm »
great thanks
Logged
flathead31coupe
Trade Count:
0
Jr. Member
Offline
Reply #8 on:
March 02, 2009, 06:07:22 pm »
Quote from: flathead31coupe on March 02, 2009, 12:43:12 pm
great thanks
you guys were right on point, cleaned and lubed up where needed works great, another? is their an adjustment to help the arm start on the record, i need to give it alittle nudge to get it playing, it runs just outside of the starting point on the record....
Logged
Ken Layton
Guru
Trade Count:
+1
Full Member
Offline
Technician
Reply #9 on:
March 03, 2009, 12:06:36 am »
The manual shows the tone arm adjustments: needle landing/lead-in.
Logged
ami-man
Trade Count:
0
Full Member
Offline
Reply #10 on:
March 03, 2009, 06:25:21 am »
Hi,
Ken is correct you need to get the manual before you start making any adjustments to the Mechanism. If you adjust one thing then it can lead to more adjustments also if one thing is out you can bet that most other adjustments will also be out.
Regards
Alan Hood
ami-man
UK
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
