Author Topic: Help with cracks on my slikstik cab...  (Read 1475 times)
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
« on: January 27, 2009, 09:38:08 am »
I noticed this weekend when i was working in my gameroom both sides of my slikstik cab has cracks running down the sides from the 90 degree where the cp sits on the cab headed for the floor.  15" on one side & 10" on the other.  I thought about running glue all the way down the cracks & painting over.  Worst case I if the cracks go to the floor just build a new cab & use the cp & guts from the slikstik any ideas on crack repair
dm
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
Blanka
Re: Help with cracks on my slikstik cab...
« Reply #1 on: January 27, 2009, 09:40:21 am »
 :pics
thatitalian
  • The Revolution Is Coming...
« Reply #2 on: January 27, 2009, 09:40:41 am »
...any ideas on crack repair
dm
What have you been doing with your crack DM!? :laugh2: :laugh2: :laugh2:
divemaster127
« Reply #3 on: January 27, 2009, 09:41:46 am »
you guys are a lot of help :laugh2:
« Last Edit: January 27, 2009, 10:22:29 am by divemaster127 »
Hoopz
  • Last login:December 02, 2025, 03:05:33 pm
  • Intellivision Rocks!
« Reply #4 on: January 27, 2009, 10:07:20 am »
Bondo?  That may be overkill though.   :dunno
« Reply #5 on: January 27, 2009, 10:29:31 am »
JB Weld rocks ;)
NoOne=NBA=
« Reply #6 on: January 28, 2009, 08:55:30 pm »
Given where the cracks are, I would try to spread them a bit, and get some Gorilla Glue in there.
If you use Gorilla Glue, it will expand, and require you to touch up the outside of the cabinet, but will be stronger than the original wood.
You are going to need a couple bar clamps, or a band clamp with a call block across the front.
Once the glue is set on the original cracks, I would reinforce it by gluing small chunks of wood across the inside.
The glued panels on the inside should prevent any separations from occurring just outside the glue joint.
