Author Topic: Anyone else use these layouts? Is MALA crashing on you too?  (Read 5066 times)
vetteguy112233
  • Last login:April 28, 2012, 12:15:24 am
« on: January 20, 2009, 09:43:42 pm »
I decided to convert these layouts for use in Mala (with the Mala layout converter). They all seem to work except the Mame (Arcade Classics), layout, which seems to crash Mala. It will display, but always crashes.
Just curious if anyone else is using these and if you had any problems?
http://www.emuchrist.org/cpviewer/mamewahlayouts_bw.htm
  • Last login:January 10, 2026, 01:53:23 pm
Re: Anyone else use these layouts? Is MALA crashing on you too?
« Reply #1 on: January 21, 2009, 11:16:53 am »
I just downloaded the mame one and am trying it, so far no crashes.
A quick question, and I havent searched for it, so if some one can link to a post, that would be great.
How can I get just the background?
I like the mame one, but I want to strip everything off and use the background for my setup.
loadman
    • MaLa
« Reply #2 on: January 21, 2009, 05:03:48 pm »
If you just want the background don't bother with the converter as it does not do anything to the graphics anyway. It just convertes the text and image size & positions
So just grab the image using the mala layout editor
« Reply #3 on: January 22, 2009, 08:07:59 pm »
I tried that, but the image still has the boxes with blue lines on it.
I would like to just have the space background.
SGT
  • Last login:May 31, 2025, 10:10:32 pm
« Reply #4 on: January 22, 2009, 08:36:03 pm »
The author of the background added the lines with a 3rd party app such as photoshop.  You need to contact the author for the original without the lines.
SGT
« Reply #5 on: January 22, 2009, 09:21:03 pm »
After looking more closely, I see the author included the photoshop project files.  I pulled out the background layer and attached it.  Is this the one you wanted?
I am assuming that John E. Crouse should get credit for these layouts and this image?
« Last Edit: January 22, 2009, 09:25:44 pm by SGT »
system01
  • Last login:March 04, 2023, 08:06:55 pm
  • System Idle Processes are the Devil's Playthings
« Reply #6 on: January 23, 2009, 12:07:31 am »
I believe that was done originally by GSXRmovistar way back (Game Not Over).  Found it on DeviantArt:
http://dinyctis.deviantart.com/art/Cosmic-Frostbite-V1-860248
« Reply #7 on: January 23, 2009, 07:06:21 am »
Great! Thanks a lot. It looks pretty good with my layout, I just need to reposition some objects now to better see the background.
To who ever wrote it created it, thanks to you also, you do good work!
vetteguy112233
« Reply #8 on: January 24, 2009, 11:09:49 am »
So far, I've disabled the MAME screenshots option and that seems to have fixed my problem.
I'm not sure why MAME's screenshots conflict with these layouts, but it seems to be fixed now.
I just have to figure out how to get my screenshots back now.
SGT
« Reply #9 on: January 24, 2009, 06:21:26 pm »
Have you seen this?:
http://forum.arcadecontrols.com/index.php?topic=83600.msg873881#msg873881
If your screenshots use RGB (True Color) instead of indexed color, they will crash Mala.
loadman
    • MaLa
« Reply #10 on: January 24, 2009, 08:27:09 pm »
What he said and
Can you replace one or two of the mame snapshots with the ones I have and see if it is OK displaying these games?
And post an example here of a pic your are having issues with
