Author Topic: trackball dilemma...MODIFIED: need review of Electric ICE-T trackball  (Read 5317 times)
severdhed
  • RIP Dinosaur Hippo
well, i hit 90 views and not a single response...so time for some modification.    do any of you have an electric ICE T trackball, and if so, how do you like it? i really want a blue trackball...if it lights up, thats cool, if not no big deal.  a friend of mine has a happ trackball, it works great.  i have found reviews of the utrak, which seems to be a great product as well.  u have not found a good review of the electric ice t trackball though.  i really just want the best option.  as long as it is blue, or can be lit up blue, i am OK with it.  mainly though, i want it to be smooth and responsive.    for those of you with a utrak..does the usb interface allow for mouse buttons to be connected?
thanks for any help you can provide...
original post is below:
well, i hit another snag in my upgrade project.  i finally got the money together to order my u360s and misc buttons and things, and my monitor died....no big deal, i'll get another here shortly...but then today i am building a temporary control panel to mount my new stuff in, to see if i like the curved button layout and to test my trackball mounting plate installation...and as it turns out my trackball no longer works.
i have an old WICO 3" trackball that was lying broken in the bottom of the empty cabinet i bought a few years ago.  the rollers were really worn, bearings were shot, and part of the plastic housing that holds the roller in place was broken off.  i managed to fix the housing so that the bearing was held tightly in place, replaced the rollers and bearings and got it working using a hacked mouse.  even with the new rollers and bearings, it doesnt feel very smooth..even after extended playing it, it is rough, and quite noisy....anyway when i hooked it up to my other pc tonight, it woudlnt move left or right..just up and down.  first i suspected my mouse hack of being the problem, but after checking connections, and swapping a few things around, it seems as if one of the optical circuit boards in the trackball is dead.  if i swap them, it stops moving up and down and left and right work just fine.
so now i need to get a new trackball.    my original plan was to build the new panel with teh u360s and new buttons...i bought a trackball mounting plate so i could use my wico ball w/ mouse hack for a while.  eventually i was going to buy a turbotwist spinner and connect my trackball to it's interface, eliminating my mouse hack...and eventually replace the trackball.  but that isn't going to work out.  i want a trackball much more than a spinner, so it has to come first.  i looked around at my options, and while some are cheaper than others, i dont want to save a few bucks now, only to regret it later and have to spend more to replace it again.
x-arcade has their trackball controllers on sale right now for $49.99, which is a good deal.. however they are plain white balls, and i have no idea how they compare to the other available options.  i just bought the u360s to replace my x-arcade controls that i am currently using...so i am afraid i will not be satisfied with this product as well.
the color scheme on my cabinet is blue and yellow, so ideally i would like a blue trackball.  this leaves me with 3 options that i could see:
a standard happ 3" trackball, these come in blue.  i can use my mouse hack until i buy the turbotwist spinner later
an ultimarc U trak, i can get the pearl ball and then purchase the optional lighting kit to make it blue
an electric ICE unit. once again, get the pearl ball and use the inlcuded lighting to make it blue.
all will cost me around the same ammount of money.  i dont necessarily need the trackball to light up, but it would be nice i guess.   i did some searching on the forums, but i couldn't find the right info that i need to make this decision.
the Utrak is cool, since it doesnt require a mounting plate..however i already have a mounting plate, so that is no big deal.  i plan to route out the top of the panel so the mounting plate sits flush with the wood, and then cover it in plexi.  i also couldn't see if the utrak interface supports mouse buttons or not.  plus with my 3/4" panel, it would require some routing anyway to get a good fit.
you cannot go wrong with a happ ball, but it needs to use my mouse hack, and is not backlit
so i am leaning towards the GGG electric ICe trackball.  it is the most costly out of the choices, but also includes everythign you need in one package....
i looked around but didnt see any reviews of this product....does anyone here have an electric ICe trackball, and if so, how do you like it?  it is alot of money to spend on something..i want to make sure it is going to be awesome.  i see that there is an optional wiring harness to connect mouse buttons, and I am assuming it will work with a 3" happ mounting plate...is this correct?
« Last Edit: January 13, 2009, 12:17:33 am by severdhed »
DashRendar
Re: trackball dilemma...MODIFIED: need review of Electric ICE-T trackball
« Reply #1 on: March 04, 2010, 03:16:22 pm »
I see this was posted over a year ago.  What did you end up getting severdhed?
severdhed
« Reply #2 on: March 04, 2010, 03:57:08 pm »
i forgot about this thread...
i ended up buying the Utrak from Ultimarc, with the translucent pearl ball, the lighting kit and trim ring(which i didn't use).  i really wanted mouse buttons, and since the utrak's usb interface doesn't support them, i purchased an optiwiz from groovygamegear.
i am very pleased with this setup.  the Utrak was easy to work with and mounted beautifully in my wood panel covered in plexi.  the blue backlight makes it look very nice, and it perfroms quite well in everything from centipede to world class bowling.
i highly recommend the utrak.
as for the optiwiz, i am also very happy with it.  the performance is great, it was easy to get set up and working, it supports 3 mouse buttons, and best of all, the price is right.
if i had to do this all over again, i would do it exactly the way i did.  Utrak+Optiwiz= ;D
DashRendar
« Reply #3 on: March 04, 2010, 04:01:28 pm »
Yeah, I'm debating about that one or GGG's ElectricIce trackball (which appears to be out of stock).
My issue is the plexi that covers my control panel.  Not sure if I'd need to route out some space on the bottom of it or not.
I'm also not sure about a track plate.  Ultimarc's trackball doesn't use a track plate, which is nice since I have a nice control panel overlay that will be going on there as well.
severdhed
« Reply #4 on: March 04, 2010, 04:33:29 pm »
how thick is your panel?  i used 5/8"MDF with 1/8" plexi, this made it fit perfectly
DashRendar
« Reply #5 on: March 04, 2010, 04:36:28 pm »
I have a Mameroom control panel; I'll need to measure the thickness of it and the plexi when I get home.
Regarding buttons for the trackball- do you use those basically for Windows (ie, double mouse clicks etc)?
Epyx
  • "You're an oddity"
« Reply #6 on: March 04, 2010, 04:48:18 pm »
The 3" RGB upgrade kits fits very nicely in the Betson Imperial/Xgaming trackball...plus with the X Gaming you get 4 mouse buttons and USB support.
Ive mentioned it a few times before but the one exception to Xgaming parts is their trackball...its mod friendly...4 screws->lift top->remove old ball and put the GGG upgrade..screw closed, It's USB so no fussing and its cheap in price but feels sturdy...again its a clone of the Betson Imperial which I have always been a fan of.
Last Project
Epyx Tutorials:
Tutorials
severdhed
« Reply #7 on: March 04, 2010, 08:56:24 pm »
i use my mouse buttons for lots of things.  i dont have dedicated mouse buttons like some people, because i didn't see the need for them, plus i didn't want the extra clutter.  the way i have it set up, player 1's buttons 5 and 6 are wired up as left and right mouse buttons.  i just configure mame to use the mouse buttons for these inputs, and they function just like any other button in games that use that many buttons (mostly fighters).  however when i need mouse buttons (for admin stuff, configuring the front end, windows stuff) i have them.
DashRendar
« Reply #8 on: March 05, 2010, 04:13:07 pm »
Good advice there.  I would prefer to order from Randy, but since he's out of stock, had to get the X-Arcade trackball, which I'll modify with his Electric Ice kit.
Hopefully I'm not sacrificing too much in the way of quality...
