Author Topic: Safety Topic  (Read 2384 times)
  • Last login:Yesterday at 11:45:21 am
Safety Topic
« on: December 03, 2008, 06:50:28 pm »
Yesterday I was using the router with a flush pattern bit.
I finished the first cut and laid it down. Usually I will release the clamp on the router which lets the bit retract up into the base,  but I had another piece to cut the same way and didnt want to have to reset the height of the bit.
And usually when Im done with a cut I will unplug the router, but I didnt this time.
I laid the router down next to my mouse sander. Before I let go of the router, I accidentally hit the switch. the router bit took off.
Thankfully I didnt get in the way of it, but my poor mouse sander did, and thankfully the sander wasnt plugged in, the short circuit could have ruined the bit, or worse yet set some of the MDF dust on fire.
The router was probably on no more than a second, but that was plenty of time for the router bit to chew up the mouse sander cord.
I have since fixed the cord but it made me think that it could have easily been one of my limbs, which probably would not have fared as well as the cord did.
Here's a picture of the chewed up cord and just a reminder that a router is a very good tool, but it can be very dangerous, especially if you get in a hurry while using it.
Mauzy
Re: Safety Topic
« Reply #1 on: December 03, 2008, 07:21:52 pm »
Things like that really make you think. When I first started soldering a year or so ago, I let the iron rest on the cord of the work light I was using. By the time I smelled the burning plastic across the room, the cord melted enough to trip a breaker. Luckily the outlets and lights were wired independently as the overhead light allowed me to at least get the iron off of the wrecked cord. Scared the crap outta me.
Bluedeath
  • Last login:June 19, 2014, 11:20:09 am
Re: Safety Topic
« Reply #2 on: December 04, 2008, 06:00:49 am »
I melted the soldering iron powercord .... with the solderiing iron of course.
I give up  fighting keyboard dislexia, I lost.
arzoo
  • Last login:January 26, 2025, 08:51:53 am
  • Robots WILL kill you.
    • LEDBlinky
Re: Safety Topic
« Reply #3 on: December 04, 2008, 08:35:25 am »
Occasionally when I'm using a power tool - usually the table saw, I have these morbid thoughts as to how easily I could off, well you get the picture - it keeps me alert. I've heard they now have technology which allows a table saw to detect the contact with flesh and stop the blade instantaneously before and damage can be done.
Robots will kill you.
Arcade Addiction
Kevin Mullins
    • Me on Myspace
Re: Safety Topic
« Reply #4 on: December 04, 2008, 08:54:15 am »
I've seen the demonstration of those and there are some videos online of them in action. As cool as they may be, I still see the urgency in taking every usual precaution. Just a damn scary thought of what could happen.
Heck, what if that new technology fails?
Having several knuckle busting, appendage cutting, concussion causing hobbies.... I can't stress safety enough in all that you may do. It's all too easy for that one time to happen.
DrFrag
  • Last login:December 15, 2011, 10:14:47 am
    • MAME Cab Worklog
Re: Safety Topic
« Reply #5 on: December 10, 2008, 04:56:02 am »
My (cheap) router has a safety mechanism, whereby it won't turn on unless it's being held vertically.
BASS!
  • Just have fun.
Re: Safety Topic
« Reply #6 on: December 10, 2008, 05:34:36 am »
I've got the fix! Just install breathalyzers on all power tools.
daywane
  • GRRRR!
Re: Safety Topic
« Reply #7 on: December 10, 2008, 07:21:30 pm »
this made my wife buy me a table saw.
I had 4 saw horses set up. I was ripping a 4 x 8  sheet of MDF in half
4x4 feet.
the two mid saw horses gave out
down I went. saw did grab my shirt.  right at chest level.
she saw this happen
I hit the scale at 220 pounds . she grabbed me and tossed me like I was a doll. She is 5 foot 3 and 135 pounds
SCARED the CRAP out of me
I have had a chain saw grab my pants leg 2 times in my life also.
1 of those  times was this year.
A can of dip in my front pocket kept the saw from my skin.
SavannahLion
Re: Safety Topic
« Reply #8 on: December 11, 2008, 01:29:23 am »
It's called SawStop. The technology is really quite beautiful. If I ever shell out for a new tablesaw, that's the one I want. But there are two kinks that I know of with SawStop. The first is, if the table safety stop is ever triggered, it's a one time thing. The table saw actually needs to be repaired with a new part costing between $70 - $100 a piece. Given the cost of a lost finger, $100 isn't a big deal.
You're absolutely right though Kevin. It's very possible for a someone to fall into a false sense of safety with this tool then get into some real trouble if they ever use a table saw other than the SawStop. That scares me more than using my dad's old home built table saw. There's no sense of security with it and it makes me more cautious.
I've done a lot of stupid stuff with tools I guess. Probably the most memorable was with a fabric cutter where I used to shave off my thumbnails while changing the blades. Blades were so ---smurfing--- sharp most people had no idea when they cut themselves.
FrizzleFried
    • Idaho Garagecade
Re: Safety Topic
« Reply #9 on: December 11, 2008, 07:13:15 pm »
That is awesome.  I was wondering how it works.  Evidently the blade is electrically charged and when it detects a variation in the current it jams a break in to the blade and the momentum of the blade drops the blade in to the table.
Quite impressive.
BASS!
  • Just have fun.
Re: Safety Topic
« Reply #10 on: December 11, 2008, 08:10:45 pm »
Man that is awesome, one question remains tho. How will I cut my hotdogs :dunno
Mauzy
Re: Safety Topic
« Reply #11 on: December 11, 2008, 08:23:22 pm »
SawStop.
That is the single greatest thing I've ever seen. I want one of those...
TelcoLou
  • Four score and seven years ago our fathers brought forth on this continent, a new nation
  • Last login:October 14, 2010, 01:28:19 am
  • Playing video games since 1977
Re: Safety Topic
« Reply #12 on: December 11, 2008, 08:25:56 pm »
SawStop.
I was watching that TV show "Time Warp", and they had a segment where they were demonstrating it in super slo-motion. Quite impressive indeed.
So a leper walks into a bar and as he gets his beer, a finger falls off. The bartender who is serving him turns and pukes all over the place. The leper, feeling bad, says, "Was it my finger falling off?" The bartender turns to him and says, "No, it's the guy dipping chips into your back."
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
Re: Safety Topic
« Reply #13 on: December 11, 2008, 09:20:31 pm »
That Sawstop is fantastic. You will never really know until it happens if it works or not, but even if it takes a chunk out of a digit, it's better than losing one.
Since having a stroke last year I'm not allowed to use power tools for safety reasons (nor can I get insured!) but luckily the fellas who work for me took over and learned from me. I do worry about their safety as they're less cautious than me, so maybe I will invest at some point.
Routers sure are dangerous things and in all truth most power tools are compromised as they wear/get dusty/retain moisture. Luckily for me tools tend to break on me before they end up causing damage and in the UK we got the extra risk from high voltage outlets...
RecklessAbandon
  • Last login:October 03, 2009, 04:29:46 pm
    • the rusty joystick
Re: Safety Topic
« Reply #14 on: December 12, 2008, 03:52:24 pm »
on sites only 110v is allowed
amerish
  • Last login:June 20, 2015, 11:01:33 am
  • Why build 1 when you can build 2 at twice the cost
    • You Saw It On TV
Re: Safety Topic
« Reply #15 on: December 14, 2008, 07:19:56 pm »
Here is a basic safety tip. Never ever ever ever cut T moulding with the blade facing you. Nearly severed a tendon in my right hand on my pointer finger and took a good chunk out of my middle finger. Good thing for butter fly stiches.
So all you kids out there, do like I say, not like I do. Always cut away from your body.
Re: Safety Topic
« Reply #16 on: December 14, 2008, 07:58:03 pm »
You just need the proper safety equipment for you, or anyone who will be with you while your working with these tools:
For the Men:
The dog:
The women:
The idea of losing your fingers to make a video game... it's like... 10,000 spoons and all I need is a knife.
