Author Topic: electronics question  (Read 1932 times)
BORIStheBLADE
  • Last login:February 03, 2012, 10:53:59 pm
« on: November 26, 2008, 08:53:53 pm »
Does anyone know a place on the internet that carries 12volt timers that can run something for a set time and turn it off for a set time?
I'm having trouble finding some.
thanks
protokatie
Re: electronics question
« Reply #1 on: November 26, 2008, 09:04:42 pm »
http://nativeoutdoors.stores.yahoo.net/pt-6.html
I just did a google for timers 12 volt and there are tonnes. That is just the first one I found. Works with both 6 volt and 12 volt systems. (I presume it is made for stuff like furnace controllers, or relayed switches for lighting-banks... dunnno)
EDIT: Looks like it was made for blower and heat switching and control. Might work for what you want
EDIT2: Its on a hunting site, and is a Remington. I therefor have NO idea what its intended use is now.. Anyone have an idea?
« Last Edit: November 26, 2008, 09:07:59 pm by protokatie »
Bleagh
  • Last login:October 18, 2016, 04:33:25 pm
    • BLEAGH!
« Reply #2 on: November 26, 2008, 09:37:17 pm »
cameras for spotting wild life?
BORIStheBLADE
« Reply #3 on: November 26, 2008, 09:46:24 pm »
Thanks for the link.
I'm actually looking for something with maybe dip switches, no screen.
Kevin Mullins
    • Me on Myspace
« Reply #4 on: November 26, 2008, 11:20:36 pm »
Automatic feeders .... http://www.nativeoutdoors.com/deerfeeders.html
  • Last login:Today at 08:30:37 am
« Reply #5 on: November 27, 2008, 09:42:18 am »
I dont know how electrically inclined you are, but you can build one using a 556 IC timer.
BORIStheBLADE
« Reply #6 on: November 27, 2008, 12:34:59 pm »
Thanks for the info, I'm going to look into them.
« Reply #7 on: November 27, 2008, 01:17:50 pm »
Although it would be more expensive, you could use a nutchip.
It has 4 inputs and 4 outputs.
You could tie four dip switches to the inputs and give you the selectable timing rates you are looking for.
The nutchip is programmable with a serial connection to your computer.
Once you program it, you dont need to leave it connected to the PC. Plus it uses 5 volt power.
Learn more about the Nutchip
Edit: I was thinking of another post where someone wanted 5 volt timers. You will need to add a 5 volt regulator to use the nutchip on 12 volts.
« Last Edit: November 27, 2008, 01:19:56 pm by DaOld Man »
