Author Topic: What's the best way to round or "scallop" a control panel top?  (Read 3655 times)
Numbski
  • Last login:November 03, 2020, 01:51:50 pm
    • Numbski
« on: November 05, 2008, 12:14:24 pm »
So I'm finally getting around to re-doing my control panel this weekend.  Making some tweaks to the box, and completely re-doing the top.
One of the things I screwed up badly the first time around was the corners.  I just took a glass, traced the bottom around the corners where they intersected, and cut.  Not the most scientific way to do it, and the results were *terrible*.
The only thing I can thing to do is drill a small pilot hole, and I have a circle cutting attachment for my roto-zip rotary saw, and just use that as though I were cutting a full circle, but just cut the rounded edges.  Is there a better way to attack this?
Build a man a fire, keep him warm for the night.
Set a man on fire, keep him warm for the rest of his life.
  • Last login:Today at 12:10:15 pm
Re: What's the best way to round or "scallop" a control panel top?
« Reply #1 on: November 05, 2008, 12:16:51 pm »
How big of a curve?
I would draw the arc out on a piece of MDF, cut it and sand to the line and then use that piece as a template with my router for all of the corners.
Numbski
    • Numbski
« Reply #2 on: November 05, 2008, 12:54:34 pm »
Not sure how big I want to do.  Here's a shot of the last attempt (early shot, ignore the fugly wannabe CPO):
« Reply #3 on: November 05, 2008, 01:02:19 pm »
How big of a curve?
That's the way to go right there.
Numbski
    • Numbski
« Reply #4 on: November 05, 2008, 01:05:35 pm »
So get an extra big flush-trim bit then?  Take a scrap piece of 5/8" board, cut my curve there, then clamp or screw that to the work piece, and flush-trim bit the thing?
Franco B
« Reply #5 on: November 05, 2008, 01:18:21 pm »
If you can find a vegetable/processed food can with the right radius you could cut around the side of the can about 3/4" from the bottom and then screw that to the CP top to use as a template for your router to follow. Should give you a perfect curve.
shiloh
  • Last login:May 10, 2016, 02:58:07 pm
« Reply #6 on: November 05, 2008, 01:21:47 pm »
How big of a curve?
I am redoing my CP and that's how I plan to do it too.
One question: is worth getting a belt sander to sand the curves or elbow grease will do it?
« Reply #7 on: November 05, 2008, 02:06:52 pm »
If you want to be that exact I wouldn't use a belt sander... one moment leaning too hard and now you have to fill it.  They eat stuff fast.  I'd cut it close and use a palm sander with like 80 grit.
« Reply #8 on: November 05, 2008, 02:37:07 pm »
That's a great idea too - or at least use it to make the template.
I would NOT use a belt sander.  MDF sands super easy by hand.
Numbski
    • Numbski
« Reply #9 on: November 05, 2008, 03:01:33 pm »
I like the can idea.  I think I'll give that a shot! :)
fjl
  • Pixels Rule!
« Reply #10 on: November 14, 2008, 02:57:26 am »
My mom told me that pointing is rude.  :-\
