Author Topic: router question  (Read 1235 times)
steve_pss
  • Last login:December 19, 2020, 06:56:53 pm
router question
« on: June 16, 2003, 11:50:29 am »
cabinet 2 is soon to be underway and this time its t-molding or bust.
soooooo
i need a router. will this cheap-o ryobi suffice? i dont feel like spending a fortune on router i'll only use for slot cutting the t-modling in. i used .5 " MDF for my last control panel with good success so recessing really isnt a factor either.
http://www.homedepot.com/prel80/HDUS/EN_US/diy_main/pg_diy.jsp?CNTTYPE=NAVIGATION&CNTKEY=market%2fpg_zip_code.jsp&BV_SessionID=@@@@1584659575.1055778097@@@@&BV_EngineID=ccdeadciijjjghhcgelceffdfgidgki.0&DRC=4&catOID=100014760
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
Re:router question
« Reply #1 on: June 16, 2003, 12:13:47 pm »
your link goes no where. (even the full link)
I'm guessing its the 60 dollar 1 1/2 hp 8 amp model? Yup, it'll work find. Thats about the specs of my Ryobi and it chews through mdf like a charm. Even solid oak works fine with a good bit.
If you build a frankenpanel, chances are I don't care for you as a person.
steve_pss
Re:router question
« Reply #2 on: June 16, 2003, 12:23:21 pm »
you guessed correctly Brax, thanks for the info.
Once again I say, my wife is going to kill me.
REBIRTH
  • Last login:December 28, 2023, 09:10:29 pm
  • What is that?
    • REBIRTH "Rotating Arcade"
Re:router question
« Reply #3 on: June 16, 2003, 12:39:37 pm »
I have the ryopbi and worked like a charm.  I have a few Ryobi products and like them all, especially at the price.  As Brax said, the bit is the key.
:) Rotate or die! :)
