Author Topic: [ATOMIC FE] Atomic Front End 0.20 Standard Edition Released!  (Read 28003 times)
Necro
  • Last login:December 31, 2025, 03:36:17 pm
  • Building a 'Classic' MAME Cab
Re: [ATOMIC FE] Atomic Front End 0.20 Standard Edition Released!
« Reply #80 on: February 04, 2010, 08:14:39 pm »
Think I found an issue just now (or am doing something totally wrong).
Trying to test AtomicFE in a mirrored cab.  Setup a screen for mame fine.  Set the horizontal mirror option for that screen and...nothing.  Just comes up like normal.
I'm on Win7 64bit, but I'm not sure if that would cause a problem or not.
youki
  • Atomic Front End Creator
    • Atomic Front End
« Reply #81 on: February 05, 2010, 03:45:09 am »
Hi, i answered you on the support forum.
I will check this week end.  This feature should work i didn't remove it . But i didn't test it since years.
So if i found a problem i will fix it.
Necro
« Reply #82 on: February 05, 2010, 08:43:20 am »
Youki, you rock.  Thanks so much.  I think I def. want to use Atomic since I can do an incredible layout that will make my layout look just like OmegaRace (since it's an Omegarace Cab).
Fancy Feast
  • Last login:December 21, 2012, 01:31:32 am
« Reply #83 on: February 06, 2010, 04:50:34 am »
Is Atomic able to kill programs that run in the system tray?  I've got VJoy.exe launching alongside one of my emulators, but it doesn't close after I quit even though I set the option to kill it when returning to the frontend.
youki
    • Atomic Front End
« Reply #84 on: February 07, 2010, 08:52:30 am »
You can run an external command when you back to the Front end to kill it.
You just have to find a exe to do that (microsoft did some , or third party exists too) .
And you will have to put as external command for your screen in Atomic something  like  : "c:\whereisyourfile\killapp.exe YourProcessName"
Havok
Fancy Feast
« Reply #86 on: February 09, 2010, 02:10:04 am »
Thanks, I'll give that a try.
scept1c
  • Last login:December 15, 2011, 11:21:14 am
« Reply #87 on: February 19, 2010, 09:46:22 am »
the download link seems not to work?
Havok
« Reply #88 on: February 19, 2010, 10:08:55 am »
Download links work for me...
youki
    • Atomic Front End
« Reply #89 on: February 19, 2010, 01:48:42 pm »
works for me as well.  :dunno
92greenyj
  • Last login:January 02, 2012, 06:19:41 pm
« Reply #90 on: May 20, 2010, 07:26:46 pm »
Youki,
I am in the process of setting up my computer for my cab. I downloadad MALA first and played around with it a little, then I downloaded and tried Atomic. I am definitely using your front end. the features are fantastic and set up has been pretty easy so far (haven't even looked at the tutorial. though i will now as I want to set up the first screen as a "system select" screen to choose the system emulator then get a game list for that system) I'm sure i will have questions as I go but i just had to say how great your FE is. and this is from somebody who knows very little about PCs (Mac guy thru and thru) and who has only been toying with the program for about an hour and a half
youki
    • Atomic Front End
« Reply #91 on: June 01, 2010, 01:51:55 am »
Thanks a lot. :)
Don't hesitate if you have question.  But it would be great if you can post them on the official support forums here :
http://spaceinvaders.7.forumer.com/viewforum.php?f=13&sid=4e7122bba52027ad7f0de0bc4d256493
Or here , but if i didn't responded in the following 2 days, send me a PM . I'm very busy right now and i come here less often.
