Author Topic: U360 plug-in issue  (Read 6363 times)
Ummon
  • Trade Count: (+13)
U360 plug-in issue
« on: October 20, 2008, 12:17:10 am »
I've found in Congo Bongo, the 4-way diagonal map is not being applied. ??
Yo. Chocolate.
Stephen Hawking
fatfingers
  • Last login:April 17, 2025, 05:26:08 pm
  • Got UltraStiks?™
Re: U360 plug-in issue
« Reply #1 on: October 20, 2008, 06:28:02 pm »
No, it is not.  Congo Bongo just reports itself as a 4-way game, not 4-way diagonal (actually, there's no such thing in mame controls).  If you want it to work, just copy the qbert.ugc file to congo.ugc (or congob.ugc, whichever the name of the rom is).
Good luck.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
W.W.P.M.D.?                                       I'm here to help ... I just don't do it. ™
Ummon
« Reply #2 on: October 21, 2008, 09:49:10 pm »
Mmmm. I was thinking I might have to modify for various games anyways. Thanks.
Yo. Chocolate.
Stephen Hawking
Ummon
« Reply #3 on: October 22, 2008, 04:49:07 am »
Is there an easy way to modify this (or is that required?) to use it with mame in any directory?
Yo. Chocolate.
Stephen Hawking
fatfingers
  • Got UltraStiks?™
« Reply #4 on: October 22, 2008, 08:13:52 am »
Not really sure what you mean.  This plugin works with MaLa, not MAME.  Sure, it enables you to use the correct controls in MAME, but it doesn't care at all what version of MAME you're using.
Does that help or did I misunderstand?
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
Ummon
« Reply #5 on: October 23, 2008, 06:30:50 pm »
I meant, a way to use it with mame alone. Ideally, running in the background of Windows that would actuate when a case of mame is run, but at the very least directory-specific to mame alone.
Yo. Chocolate.
Stephen Hawking
fatfingers
  • Got UltraStiks?™
« Reply #6 on: October 26, 2008, 12:22:25 pm »
Hmmm...not that I can think of (easy, anyway).  Somehow it would have to detect mame starting up and what game it was started with, then figure out the controls for that game, and then map it.
Maybe someone smart can do it?
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
TheShanMan
    • My Arcade (updated 1/30/13)
« Reply #7 on: October 26, 2008, 12:55:55 pm »
Actually I think it could be done fairly easily using MAME's output system, which broadcasts various kinds of information to apps that are registered listeners. I think it broadcasts the name of the game at startup (and broadcasts exit too). ledutil is kind of a sample app for that. Several of us have done work with the output system (me, headkaze, and I'm sure others too), so you could always check in with one of us for help.
fatfingers
  • Got UltraStiks?™
« Reply #8 on: October 26, 2008, 02:44:27 pm »
Interesting.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
Ummon
« Reply #9 on: October 27, 2008, 07:23:13 pm »
Yeah, neat.
Yo. Chocolate.
Stephen Hawking
fatfingers
  • Got UltraStiks?™
« Reply #10 on: October 28, 2008, 11:47:20 am »
If someone made me a list of these 45-degree games, it would help me out a lot.  rom names would be the most beneficial.
Thanks.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
TheShanMan
« Reply #11 on: October 28, 2008, 04:39:52 pm »
I only know of congo and qbert. Unfortunately I don't think there is any way to generate a list. I did a text search on controls.xml though and these are the games I found (rom names):
  • congo
  • inferno
  • qbert
  • qbertqub
  • sqbert
All but inferno have control type of "Diagonal 4-way" as listed in controls.xml (inferno is different because it has 2 diagonal 4 ways, with 1 being a trigger stick). So in reality if you just handle that control type, and then handle inferno as a special case, I think you'd be golden.
fatfingers
  • Got UltraStiks?™
« Reply #12 on: October 28, 2008, 04:52:56 pm »
Hmmm...except qbert and congo just get reported to the plugin as 4-way, not diagonal 4-way.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
TheShanMan
« Reply #13 on: October 28, 2008, 04:55:07 pm »
Interesting. It doesn't use controls.xml then, huh?
fatfingers
  • Got UltraStiks?™
« Reply #14 on: October 28, 2008, 07:15:52 pm »
Well, I don't actually know what mala uses to determine the controls.  I assume it would be controls.xml, but what do I know.  Also, I know MAWS does not list anything other than 4-way for those games, either (at least, not the last time I looked).
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
loadman
  • Last login:Yesterday at 07:18:10 pm
    • MaLa
« Reply #15 on: October 28, 2008, 07:40:38 pm »
controls.ini
set in mameconfig - additional
Ummon
« Reply #16 on: October 29, 2008, 07:34:55 pm »
Just thought I'd mention an easy way to change map assignments is entering new data into a copy of a map file and then naming it to the map that's normally used, as in the case last night where I made a 4-way, no sticky (UD Bias) out of a copy of '4-way' and renamed it that, renaming the original so there was no conflict.
Yo. Chocolate.
Stephen Hawking
