Author Topic: Replacement T-Molding not staying in slot - suggestions?  (Read 2040 times)
cmoses
« on: September 20, 2008, 06:14:39 pm »
I am replacing some T-Molding on my project MAME cabinet.  The original T-Molding was in pretty bad shape so I took it out and have since restored the cabinet.  Now that I am replacing it with new T-Molding it slides into the slot very easy without much resistance.  I am not sure if there is a something that I put in there with the T-Molding to make the fit tighter or if I will have to use some glue or adhesive of some type.
Can I get some recommendations as to the best way to keep the new T-Molding in place?  I was hopping to get some suggestions from people that have run into the same issue.
Re: Replacement T-Molding not staying in slot - suggestions?
« Reply #1 on: September 20, 2008, 07:43:53 pm »
I'd use a glue gun.
  • Last login:Yesterday at 07:49:55 pm
« Reply #2 on: September 20, 2008, 07:55:48 pm »
I've used masking tape wrapped around the spine and it creates a very tight seal. In really bad t-molding slots I've had to refill them with bondo and recut them.
telengard
  • Last login:October 21, 2025, 02:12:46 pm
  • Yeah, it's a classic! 21+ on BYOAC and still goin
    • S T U R C A D E
« Reply #3 on: September 21, 2008, 07:22:20 pm »
I had issues w/ the far ends staying in the slot where they were going around corners.  I used a little super glue and they haven't come out since.
~telengard
S T U R C A D E     M.A.M.E. Cabinet
http://www.briansturk.com/mame.html
somunny
  • Is it hot in here?
« Reply #4 on: September 21, 2008, 07:43:25 pm »
I'd use a glue gun.
I've used this method and it worked for me.
This is also a good idea.  Wouldn't have thought of it.  Thanks for putting another option out there.  :)
cmoses
« Reply #5 on: September 21, 2008, 11:46:32 pm »
I'd use a glue gun.
Best to just shoot the glue in the slot and push in the T-Molding, then let it set?
As far as using masking tape, is one piece enough or do we need to do more?  The T-Molding goes in, a little resistance, holds ok on straight areas, just mostly at corners.
somunny
« Reply #6 on: September 22, 2008, 12:00:39 am »
I'd use a glue gun.
Yeah, load it in there but be quick about it as hot glue sets up fast, fast, fast.
« Reply #7 on: September 22, 2008, 09:00:35 am »
I thought about using glue, and I was concerned about replacing the t-molding if it got nicked up or something. I'm sure it would work though.
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #8 on: September 22, 2008, 09:57:40 am »
That's what's so great about hot glue.  It holds it well enough, but if you need to you can pull the t-molding out, as well as all the glue, with little trouble.
Best Kid iPad Apps
pinballwizard79
« Reply #9 on: September 23, 2008, 12:07:14 am »
I had this problem once
To remedy the situation I filled the groove with tacky glue, then pushed hard on the molding & then ran a really tight strip of blue painters tape from one side to the other.....every inch or two.
After it cured all was well.
cmoses
« Reply #10 on: September 23, 2008, 11:42:27 am »
Had not heard the term "tacky glue" so I Googled it.  Are you referring to Aleene's tacky glue product?  Or something else?  Aleene's is just a thicker glue, so it holds better initially.
