August 19, 2025, 03:58:29 pm
I'd use a glue gun.
I've used masking tape wrapped around the spine and it creates a very tight seal. In really bad t-molding slots I've had to refill them with bondo and recut them.
Quote from: javeryh on September 20, 2008, 07:43:53 pmI'd use a glue gun.Best to just shoot the glue in the slot and push in the T-Molding, then let it set?As far as using masking tape, is one piece enough or do we need to do more? The T-Molding goes in, a little resistance, holds ok on straight areas, just mostly at corners.
