Author Topic: Exit form EMUS with "1+2" Keys  (Read 2728 times)
Haggar
  • Last login:February 13, 2017, 05:12:32 am
« on: September 19, 2008, 03:42:35 am »
I've managed to exit from several emus by the "ESC" key.
I have no esc key on the cab, so I want to get "ESC" when I press simultaneously 1 and 2, to exit from these emulators.
There's a way to do that with MaLa?
dungbeetle46
  • Last login:June 25, 2016, 07:27:47 pm
Re: Exit form EMUS with "1+2" Keys
« Reply #1 on: September 19, 2008, 06:23:45 am »
you can exit from other emus by using the hotkeys but not sure how you could exit in mame without using escape, probably easier to put in another button
loadman
    • MaLa
« Reply #2 on: September 19, 2008, 07:15:19 am »
If you want to set other keys to do ESC, then that is a fuction of your keyboard encoder not MaLa.
I think I-Pac's do this by default like mine does.
Haggar
« Reply #3 on: September 19, 2008, 08:35:08 am »
How can I do that?
Mame is the only emu I use, where you can set a combination of keys (1+2 in my case) to exit (you can do that in the input config menu).
The prob are other emus, where you can only assign one key to a function.
Unfortunately I have no i-pac.
BTW I was wondering if there is another way to exit from emus and return to MaLa without the use of the keyboard (some sort of hotkey).
PS: Thank you for this piece of software (and the new release! :) )
« Last Edit: September 19, 2008, 08:38:17 am by Haggar »
dungbeetle46
« Reply #4 on: September 19, 2008, 09:40:26 am »
under your other emu config, go to options and edit hotkeys
now add a close key and choose 1 to close plus shift or alt etc which will be player 1 start button and player 1 button 1 etc
now by pressing both buttons it will close
« Last Edit: September 19, 2008, 09:49:40 am by dungbeetle46 »
