Author Topic: EPSXE how to run in Lazarus?  (Read 3404 times)
Demon-Seed
    • DemonCade (WORKING URL!)
« on: June 12, 2003, 01:57:01 pm »
Hey anyone help me out. Got it to show up in the Lazarus list, and games, when i run it from Lazarus it only opens EPSXE and u have to use the mouse to hit RUN ISO. Is there a way to do it so it loads auto?? I have tried playing in command mode but it only load EPSXE not into the game? ie)  E:\EPSXE.exe G:\PSX ROMS\dead or alive.ISO
thanks in advance.
JIM
CM
  • Last login:January 02, 2012, 08:59:17 pm
  • The internet?!? Is that thing still around?
Re:EPSXE how to run in Lazarus?
« Reply #1 on: June 12, 2003, 02:24:40 pm »
I am not familiar with EPSXE exactly, but the rule of thumb is if you want something to launch under Laz/DragonKing, make sure you know you can do it from a command prompt manually first.  Stick to debugging your problem there before trying the FE.  If you can type it in at a prompt and get it to launch the right way .. there is a 99% chance you can get it setup with a Laz wrapper to make it work.
#1 Suggestion .. use -loadbin <file>       - Loads a specified ISO image file.
#2 Suggestion .. play with quotes around your rom name .. could help with weird space handling.
#3 Suggestion .. once you can launch at command prompt, read up on Laz command-line wrapper.
Good luck!
Demon-Seed
« Reply #2 on: June 12, 2003, 07:47:24 pm »
Hey tried many things
epsxe -loadiso G:\PSX\Dead or Alive.iso
epsxe -loadiso "G:\PSX\Dead or Alive.iso"
epsxe -loadiso "1.iso"
epsxe -loadiso 1.iso
epsxe -loadiso "1.iso" PS-EXE
epsxe -load iso 1.iso PS-EXE
nothing works.. any ideas????
GSXRMovistar
  • Last login:April 16, 2025, 06:01:17 pm
  • Gez, this is gonna be expensive!
    • forum.arcadecontrols.com/index.php/topic,148135.0.html
    • CoffeeCade
« Reply #3 on: June 12, 2003, 08:01:24 pm »
Demon-seed,
I've had this working from the commandline, and from what i remember it took me an evening to get it figured out (right pain in the --I'm attempting to get by the auto-censor and should be beaten after I re-read the rules--!). I don't have the shortcuts on the pc I'm at now, but if you can wait till tomorrow I'll grab them off my other box and post them here.
GSXR.
CM
« Reply #4 on: June 12, 2003, 08:09:07 pm »
The faq has "-loadbin" instead of "-loadiso" ..  Try that.
Demon-Seed
« Reply #5 on: June 12, 2003, 09:14:31 pm »
tried it thanks though.
I would appreciate it the post when u can check your other box.
thx
Jim
GSXRMovistar
    • CoffeeCade
« Reply #6 on: June 13, 2003, 07:06:12 am »
Couldn't find that shortcut I mention but just had a quick play with it and this seems to work  :)
d:\path\to\epsxe152\epsxe -nogui -loadbin "d:\emu\psx\isos\Soul Blade.img"
Note: loadbin not loadiso, and the -nogui switch hides the interface window and pressing escape will exit.
GSXR.
GSXRMovistar
    • CoffeeCade
« Reply #7 on: June 13, 2003, 07:08:28 am »
Also, this site has a whole heap of good info for PSX emulation (and others)
http://www.ngemu.com/forums
GSXR.
AlanS17
    • AlanS17
« Reply #8 on: June 13, 2003, 10:02:40 am »
Why not just use the Lazarus wrappers? They can be used with other programs from what I understand. The whole point of the wrappers is to take programs that typically couldn't start with a command line and encases the program within another program that CAN be executed with a command line. Does that make any sense?
http://www.oscarcontrols.com/lazarus/
GSXRMovistar
    • CoffeeCade
« Reply #9 on: June 13, 2003, 10:19:30 am »
Yeah but there isn't a wrapper for ePSXe (as yet ;)), so in this case if you can get it working via the command line THEN you can use the generic command line wrapper to have it run in Laz/DK.
AlanS17
    • AlanS17
« Reply #10 on: June 13, 2003, 10:36:20 am »
The wrappers are supposed to be configurable, aren't they? Why couldn't you just set up your own?
Minwah
    • MAMEWAH
« Reply #11 on: June 13, 2003, 11:14:58 am »
Anyone have the commandline wrapper configured for EPSXE?
My FE has a hard time launching these types of emu's by itself - it likes the switches to be at the end of the commandline.
Demon-Seed
« Reply #12 on: June 14, 2003, 09:40:51 pm »
I tried it it worked but how do i set it up in laz?
i tried
extension=.iso
path=E:\PSX\
exe=epsxe.exe
send rom path=
send exit keys=0
command line options;-nogui -loadbin
and it runs it like
epsxe.exe G:\psx roms\dead or alive.iso -nogui -loadbin
How do u set it so it runs right way? I am confused! thanks
Jim
Demon-Seed
« Reply #13 on: June 17, 2003, 04:25:49 pm »
Hey Guys,
Has anyone been able to look at this and get it to run correctly? I would appreciate someone who has success running Epsxe in Lazarus to email me or leave a msg. I really am excited to add it!
thanks very much
Jim
GSXRMovistar
    • CoffeeCade
« Reply #14 on: June 17, 2003, 04:33:49 pm »
Haven't checked myself, but have you tried setting the exe as this,  "exe=epsxe.exe -nogui -loadbin", then leaving the command line options section blank?
joeblade
  • Last login:December 06, 2016, 06:14:44 am
  • Game on .. dude's
« Reply #15 on: June 17, 2003, 06:55:40 pm »
If you can't get it going with howards command line wrapper, give my generic command line wrapper a go.
You can easily configure it so that certain parameters appear before, and certain parameters appear after the
rom name.
You can find it at:
http://www.users.bigpond.net.au/joe_blade/cmd/
Drop me some feedback if you find it useful, or if you think it could do with some more features.
Cheers.
Demon-Seed
« Reply #16 on: June 17, 2003, 10:47:01 pm »
Guys,
I tired his CMD wrapper and wow! Poof.. I got epsxe running great in Lazarus! It runs and exits no problems! It was very easy to configure too! only one thing I would add is maybe a conversion list of ascii.. just so we do not have to look :) its awsome keep it up!
Jim
