Author Topic: Help with a "creaky" joystick  (Read 3464 times)
TelcoLou
  • Four score and seven years ago our fathers brought forth on this continent, a new nation
  • Last login:October 14, 2010, 01:28:19 am
  • Playing video games since 1977
« on: August 21, 2008, 12:51:24 pm »
I've been playing a LOT of shooters lately, and started to notice my Happ Competition 8-way joystick is starting to "creak" while moving; almost sounding like it needs lubrication(?). Is there a way to fix this?
So a leper walks into a bar and as he gets his beer, a finger falls off. The bartender who is serving him turns and pukes all over the place. The leper, feeling bad, says, "Was it my finger falling off?" The bartender turns to him and says, "No, it's the guy dipping chips into your back."
  • Last login:Yesterday at 05:14:12 pm
    • GroovyGameGear.com
Re: Help with a "creaky" joystick
« Reply #1 on: August 21, 2008, 12:59:13 pm »
The first step is to figure out where the noise if coming from.  I would remove the e-clip and the square actuator from the bottom of the stick so no switches can be hit and see if it still makes the noise.  If so, it's likely the internal spring.
Pull the whole thing apart and shoot some silicone spray inside the spring cavity.  Make sure you get a good shot everywhere the spring makes contact with the plastic, as well at the parts where the spring coils back on itself.  I'm guessing you won't have any creaking after that.
TelcoLou
« Reply #2 on: August 21, 2008, 01:04:46 pm »
SWeet! Thanks for the quick reply! I'll reply after I try it out  ;D
miles2912
  • Last login:October 31, 2019, 05:30:24 pm
  • My first Home Game. Fairchild System F.
« Reply #3 on: August 21, 2008, 02:23:24 pm »
The Happ competition are like hamsters.. just chuck it and grab a new one  :)
  Scratch built upright MAME Cab
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #4 on: August 21, 2008, 06:48:49 pm »
Don't waste it; if you can get rid of an irritating squeak with a bit of lubrication you're good to go. Wouldn't bin a car if it needed an oil change would you?
TelcoLou
« Reply #5 on: August 22, 2008, 01:06:37 pm »
Thanks again for the tip Randy! I worked like a charm!! Now I need to lube the other (player 2) stick  8)
« Reply #6 on: August 22, 2008, 03:36:40 pm »
No Problem.  Happy to hear it worked for you!
