Author Topic: Ultimate Arcade Plans  (Read 1628 times)
meta87
  • Last login:September 30, 2004, 07:36:28 pm
  • Dont Mess with Texas
« on: June 09, 2003, 12:40:31 am »
Hi!
I'm making my first cab with cyberpunk's plans and I seem to have hit a snag  ???
All the width measurements are 1' 1/4". This obviously can't be correct because you are supposed to be able to put a 25 inch monitor in there.
Should I just make all the width measurements 25 inches?
Travis
jakejake28
  • Last login:September 02, 2005, 07:23:54 pm
  • Thank you sir, may I have another?
Re:Ultimate Arcade Plans
« Reply #1 on: June 09, 2003, 12:44:30 am »
actually, a 25 inch moniter is not always 25 inches across. remember, the dimensions of a moniter are based off the pythagorean thereom, and that 25 inch is from bottom left to top right corners.
It's all about the Pentiums
mccall
  • Last login:July 23, 2003, 03:58:39 pm
« Reply #2 on: June 09, 2003, 10:29:04 am »
You should email him (Cyberpunk) or message him and ask. He's under that name on this site and as you probably know he has his own site. Try an email and an instant/private message on both sites and you'll probably get an answer within a day or so.
BobA
  • What Me Worry?
« Reply #3 on: June 09, 2003, 10:36:36 am »
I have the original ultimate arcade plans from Cyberpunk and the width is shown as 2 ft 1 inch inside measurement.  The only place I see a 1ft .5 inch measurement is to the center of the panel to locate a drawer pull.   Are you sure you are reading the right measurement?  The original needed a minimum of 27 inch door to fit so 25 inside + 2x.75 sides =26.5 which sounds about right.
BobA
« Last Edit: June 09, 2003, 10:41:46 am by BobA »
MikeW
  • Last login:April 12, 2005, 10:11:16 am
« Reply #4 on: June 11, 2003, 08:27:14 am »
The plans call for 2'-1" which is 25".  I made it a little larger, 27" so I could install a WG 9200 in the future.  I ended up with an NEC Multisync 27" monitor(ABSOLUTLY ROCKS FOR MAME!) and it fit with a 1/2" to spare on both sides (:
