Author Topic: Have I fried my Opti-pac??  (Read 1590 times)
heinekenlvr
  • Last login:January 19, 2022, 01:27:17 pm
« on: August 04, 2008, 04:04:06 pm »
I wired my opti-pac to a steering wheel using the appropriate hack. Everything was working fine for weeks until I diconnected everything today so I could install the hardware into my cabinet. Now, when I hook things back up, when I turn the wheel to the left or to the right, the pointer moves semi sporatically to the the left only. Have I fried the opti pac or have I done something else??
Droler
  • Last login:April 04, 2022, 12:27:23 pm
Re: Have I fried my Opti-pac??
« Reply #1 on: August 04, 2008, 07:38:10 pm »
Sounds like your optical encoder board, do you have a trackball or other controller with an encoder board you can hook up to test?
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #2 on: August 04, 2008, 07:53:55 pm »
Check all your connections and your cabinet power supply. You may have a loose connection or a bad earth.
heinekenlvr
« Reply #3 on: August 05, 2008, 02:50:24 pm »
Ok, I checked my voltage coming off the optipac and it's 5v. I checked the voltage all the way down to the encoder and it reads 5v. I am using a Pole Position steering wheel again with the appropriate hack. I checked all of the connections and they seem tight. All of the solder points seem good. Everything was working fine until I started messing with things. What is a bad earth??
_Iz-
  • Last login:March 17, 2026, 09:19:06 pm
  • Time to coin up!
« Reply #4 on: August 05, 2008, 03:24:52 pm »
heinekenlvr
« Reply #5 on: August 05, 2008, 11:07:03 pm »
Thanks. BTW, I had a look at all of the connections and back tracked. I started from scratch and decided to bypass the existing quick connector since it was over 25 years old. I soldered all the wires directly to the board and voila we have success. The Optipac is running like a charm again.
