Author Topic: My joysticks aren't working right...  (Read 1981 times)
Doom bucket
  • Last login:July 07, 2009, 11:50:26 pm
« on: July 24, 2008, 07:48:23 pm »
if the right joystick is moving the left joystick won't register anything
I just checked and they aren't registered to the same inputs...
any idea what might be going wrong?
  • Last login:October 27, 2025, 02:12:45 pm
    • GroovyGameGear.com
Re: My joysticks aren't working right...
« Reply #1 on: July 24, 2008, 07:50:12 pm »
Hmmm....what do you have them connected to?
Doom bucket
« Reply #2 on: July 24, 2008, 07:54:34 pm »
ipac, and the joysticks are Pefect 360
I'm using winkawaks
« Reply #3 on: July 24, 2008, 07:58:15 pm »
Double check your wiring.  Does left joystick work properly otherwise?
Doom bucket
« Reply #4 on: July 24, 2008, 07:58:54 pm »
Yes, it does.
  • Last login:November 13, 2025, 08:40:37 pm
« Reply #5 on: July 24, 2008, 08:02:55 pm »
Thats what you get for not using Nintendo Joysticks.
Doom bucket
« Reply #6 on: July 24, 2008, 08:04:19 pm »
It seems that if the left stick moves right and the left stick moves left there is no issue...
But if both joysticks move up, only the right joystick will register.
« Reply #7 on: July 24, 2008, 08:11:51 pm »
I'm stumped.  I think you have something miswired.
But up on the left stick works fine so long as the right stick is not up?
You have to supply more info.  Like, what combinations work, and which ones don't...all of them :)
« Last Edit: July 24, 2008, 08:15:54 pm by RandyT »
DaddyLongLegs
  • Last login:October 11, 2021, 02:23:36 pm
« Reply #8 on: July 24, 2008, 09:09:24 pm »
Thanks but did you add it to my order? And how do I pay you the difference? :)
« Reply #9 on: July 24, 2008, 10:44:57 pm »
Either the board has lost it's mind or you are in the wrong thread ;)
Please email me.
Doom bucket
« Reply #10 on: July 25, 2008, 02:57:31 pm »
It turned out to be a software problem. Once I switched over to MAME instead of Winkawaks the problem disapeared.
« Reply #11 on: July 25, 2008, 03:13:04 pm »
I knew it... you always forget a "small detail".  :laugh2:
I assume it quit working properly as soon as you switched to winkawaks?
« Reply #12 on: July 25, 2008, 03:25:34 pm »
That's some weird software problem.  :)
Glad you figured it out.
