Author Topic: Mala and Gamelist editor  (Read 5385 times)
winnydapoo
  • Last login:February 07, 2022, 05:13:29 am
« on: July 18, 2008, 05:20:37 am »
Hi all,
This is probably a noob question, sorry if it's been asked before but I couldn't find any answers when searching the forum.
I have been downloading a few roms that weren't in the all games list for mala, or in the list of games to choose from when using the gamelist editor. How do I refresh the list so the new roms show up and if there's no easy way to do that or if that doesn't work, can games be added to gamelists manually?
loadman
    • MaLa
Re: Mala and Gamelist editor
« Reply #1 on: July 18, 2008, 07:57:15 am »
Refresh the main gamelist.
Right Click when mala is running
« Last Edit: July 18, 2008, 09:50:32 pm by loadman »
winnydapoo
« Reply #2 on: July 20, 2008, 02:17:56 am »
It is greyed out when I right click....
loadman
    • MaLa
« Reply #3 on: July 20, 2008, 06:16:41 am »
the 'main' list?  Not a custom list
winnydapoo
« Reply #4 on: July 20, 2008, 07:32:04 am »
I created the game menu tree in the mala tree editor, so I don't think I have the 'main' list there now. Is there a way to get it back so I can refresh?
loadman
    • MaLa
« Reply #5 on: July 20, 2008, 09:25:18 am »
Good Question...
I don't use the tree..
RoboG2
  • P&R
  • Last login:August 15, 2008, 10:21:26 pm
« Reply #6 on: July 20, 2008, 01:48:28 pm »
I also cannot refresh any game lists, and am also using the tree.  It seems like you are having the same issue as I am, except for the fact that I cannot refresh the list from the first place.  Hopefully someone will be able to help us both.
Here is my problem thread.
RoboG2
  • P&R
« Reply #7 on: July 20, 2008, 02:16:08 pm »
This is definitely a problem with MaLa tree.  If you are having the same problem as I am, the right click options will be visible if you uncheck "Use tree" in the "GUI" tab of the options menu.  There you should be able to refresh your gamelist.  Problem is, when I re-checked the box, everything reverted back (to no gamelists and greyed-out right click options).  Hopefully you will not have the same problem as I did (and you might not if you can see gamelists in your MaLa layout).  Hope this helps!
winnydapoo
« Reply #8 on: July 20, 2008, 08:17:42 pm »
Thanks robo, that gives me some ideas to try.
winnydapoo
« Reply #9 on: July 21, 2008, 03:47:12 am »
Ok I got it to refresh. I just turned off the tree, did a game refresh, then the latest list was available in the gamelist editor :)
RoboG2
  • P&R
« Reply #10 on: July 21, 2008, 03:47:44 am »
No problem; thanks for your help also.  Good luck!
EDIT: :cheers:
