Author Topic: Help me find these brackets !!!!!!!!!!  (Read 2329 times)
ctozzi
  • Last login:November 24, 2022, 01:05:42 pm
« on: July 15, 2008, 12:59:08 pm »
I need these to finish off my MAME project but cannot find them anywere. I need the monitor glass hold down to be 27 inches and the Z shape bracket the same.
Current Cab's
Dedicated Killer Instinct 1
Mortal Kombat 1,2,3
Terminator 2
Rampage WT
WWF Wrestlemania
MAME MK1
Zelda Theme Bartop
fjl
  • Pixels Rule!
Re: Help me find these brackets !!!!!!!!!!
« Reply #1 on: July 17, 2008, 02:55:11 am »
I'd go to a metal shop, and have them make copies or something.  :dunno
ivwshane
    • My first mame cab! (WIP)
« Reply #2 on: July 17, 2008, 04:12:15 am »
I need that piece too!
Spaz Monkey
  • Last login:February 15, 2011, 11:33:55 pm
  • Hit me with a chicken quesadilla and a Coke.
« Reply #3 on: July 18, 2008, 12:16:16 am »
Ditto!
ctozzi
« Reply #4 on: July 19, 2008, 11:51:47 pm »
nobody knows were to get these ? ???????
Current Cab's
Mortal Kombat 1,2,3
Terminator 2
Rampage WT
WWF Wrestlemania
MAME MK1
Zelda Theme Bartop
  • Last login:Yesterday at 05:14:12 pm
    • GroovyGameGear.com
« Reply #5 on: July 21, 2008, 01:38:51 am »
They are very likely custom parts designed specifically for the cabinet in question.  Many places will do custom extrusions if you have large enough requirements, and the hold down looks like it's metal, which means anyone with a metal brake and a shear could make it.
IOW, it seems unlikely that you will find those parts on a shelf somewhere, unless they were made as an after market component specifically for that purpose.....or you get really lucky.
brock.sampson
  • Last login:May 31, 2018, 10:11:41 pm
« Reply #6 on: July 21, 2008, 08:45:29 am »
Do any of your existing cabinets have those parts?  I borrowed the control panel piece from a friend of mine and had my brother in law bend me one at his work.  He's in heating and air and works with sheet metal a lot.  Painted it black and screwed it on works like a champ.  If you need the same shape just longer most metal shops should be able to bend those in about 5 minutes.
DOC! YOU HAVE A TABLE OVER THERE WITH A SIGN THAT SAYS, "LASER DEATH RAY BARGAIN BIN!"
ctozzi
« Reply #7 on: July 21, 2008, 09:32:59 am »
i found the main one that goes on the glass at lowes, cut it and painted black. I'll see if I need the other when i get my panel
Current Cab's
Mortal Kombat 1,2,3
Terminator 2
Rampage WT
WWF Wrestlemania
MAME MK1
Zelda Theme Bartop
ivwshane
« Reply #8 on: August 01, 2008, 12:41:03 am »
What?
Can you give some more details? Any picks of what you did?
ctozzi
« Reply #9 on: August 02, 2008, 01:03:21 pm »
here ya go it's just a simple bracket that I bought in Lowe's for $ 5.00 and cut it to fit, then drilled holes to hold the glass and give that clean vintage arcade look.
Current Cab's
Mortal Kombat 1,2,3
Terminator 2
Rampage WT
WWF Wrestlemania
MAME MK1
Zelda Theme Bartop
ivwshane
« Reply #10 on: August 02, 2008, 04:40:05 pm »
Oh I see what you mean now.
That's pretty much how I was going to do it as well but I was hoping for a piece that would cover/connect the monitor and the cp top.
