Author Topic: Killer Instinct 2 KI2 dedicated small menu issue help ?  (Read 1376 times)
ctozzi
  • Last login:November 24, 2022, 01:05:42 pm
« on: July 14, 2008, 01:48:36 pm »
So I got this dedicated KI2 yesterday and it works flawless, however when i access the menu and try to select free play nothing happens. I cannot go any further within that sub menu, when I move the joystick or press any button to try to access that option nothing happens. I can adjust volume,and so on.... but a few options i cannot change.
Current Cab's
Dedicated Killer Instinct 1
Mortal Kombat 1,2,3
Terminator 2
Rampage WT
WWF Wrestlemania
MAME MK1
Zelda Theme Bartop
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
Re: Killer Instinct 2 KI2 dedicated small menu issue help ?
« Reply #1 on: July 14, 2008, 06:45:17 pm »
Are there other dip switches on the board? They may be options that can only be changed by dip settings, rather than by the software menu.
gatordad
  • Trade Count: (+11)
  • Last login:January 27, 2026, 09:36:47 am
« Reply #2 on: July 15, 2008, 12:04:46 am »
Here is a link to the manual, it should be in there
http://arcarc.xmission.com/PDF_Arcade_Manuals_and_Schematics/Killer_Instinct_2_(16-40064-101_Jan_1996).pdf
« Last Edit: July 15, 2008, 12:11:59 am by gatordad »
ctozzi
« Reply #3 on: July 15, 2008, 12:55:25 pm »
Thanks guys when I get home ill read throught the manual and see
Current Cab's
Mortal Kombat 1,2,3
Terminator 2
Rampage WT
WWF Wrestlemania
MAME MK1
Zelda Theme Bartop
« Reply #4 on: July 15, 2008, 05:14:30 pm »
the reason is because you have your CMOS set to dipswitch and not set to coinage. on my MK2, UMK3, and KI1 boards   its the second set of dips, switch #1
