January 28, 2026, 04:04:10 pm
I've bought a Universal Video Converter to hook my PC up to my medium res monitor, but I haven't had a chance to do it yet. Happ sells the converter (I bought mine used). It accepts a PC VGA cable as input and lets you set a jumper for standard res or medium res output. My monitor is a 38" showcase cab, and it isn't multi-frequency so I thought that was the only way I could use the monitor.
Considering your 25" med res. monitor is worth way more than a 25" std. monitor, you should sell it instead.
Quote from: Paladin on July 11, 2008, 11:56:56 pmI've bought a Universal Video Converter to hook my PC up to my medium res monitor, but I haven't had a chance to do it yet. Happ sells the converter (I bought mine used). It accepts a PC VGA cable as input and lets you set a jumper for standard res or medium res output. My monitor is a 38" showcase cab, and it isn't multi-frequency so I thought that was the only way I could use the monitor.Paladin,Let me know how you make out with this. Andy,Would I have the same issues you mentioned using the Happ converter?
