Author Topic: No green color on my monitor  (Read 6008 times)
southpaw13
  • Last login:August 17, 2025, 03:18:15 pm
  • Whatever!
« on: July 02, 2008, 11:35:25 pm »
I bought a game today and it has no green color on the game itself.  The previous owner said it probably needs a cap kit.  I opened it up to find out the monitor is a WG K7203.  It was made in 2002.  The monitor looks pretty good (clean and no burn) so I am thinking that it probably does not need the kit.  I don't have any type of testing equiptment.  How can I find out if it is really the monitor or maybe the game itself.
Thanks for your help....
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
Re: No green color on my monitor
« Reply #1 on: July 03, 2008, 09:16:57 am »
Swap the color inputs.  If the problem travels, it's the game.
Likely it's not the game.  It's probably the color transistor on the neckboard.  Green likes to go first  because it's nestled right between red and blue, and gets the heat from them.
southpaw13
  • Whatever!
« Reply #2 on: July 03, 2008, 03:36:35 pm »
Thanks!  I tried it and the monitor still did not work.  How hard and what is the easiest way to figure out which transistor it is?
Thanks for your help.....
grantspain
« Reply #3 on: July 03, 2008, 04:30:30 pm »
compare the transistors with a multimeter
SirPeale
« Reply #4 on: July 03, 2008, 05:10:30 pm »
On a WG it's almost always the middle transistor.  RGB after all.
southpaw13
  • Whatever!
« Reply #5 on: July 06, 2008, 08:24:01 pm »
Thanks, after taking the protective cover off the back of the neck board, the middle transistor made the board black.  So I am trying to find a replacement C3956 transistor.  Radio Shack does not carry them and most places on-line want you to buy in quantities.  I tried Mouser electronics too and they did not have them.  Any suggestions????
gatordad
  • Trade Count: (+11)
  • Last login:Yesterday at 09:07:22 pm
« Reply #6 on: July 06, 2008, 09:28:00 pm »
Call WG and ask for parts
SirPeale
« Reply #7 on: July 06, 2008, 09:33:14 pm »
Crosses to an NTE2521.  Mouser should have that.
Longshot, but try touching up the solder joints on all the color transistors.  I had one once that came completely unsoldered.  Once I soldered it back together it worked fine.  I'd still replace the transistor but in the meantime you could still play it.
fargen
  • Last login:July 09, 2017, 01:11:56 pm
« Reply #8 on: July 06, 2008, 09:55:16 pm »
heya, try under 2sc3956 for searching also, might have better luck. Guy on ebay has them but the shipping is high. Hope this helps...sbm
fargen
« Reply #9 on: July 06, 2008, 09:57:29 pm »
heya, also happ controls has 9 at the main warehouse so you could order from them. I dont know the minimum though...sbm
southpaw13
  • Whatever!
« Reply #10 on: July 06, 2008, 10:47:57 pm »
Thanks, I also sent Bob Roberts an e-mail.  He stocks a lot of stuff like this...
southpaw13
  • Whatever!
« Reply #11 on: July 07, 2008, 11:40:59 am »
What a pain it has been to get this part.  I ended up ordering it from Wells Gardner.
Thanks for your help,
More to come....
SirPeale
« Reply #12 on: July 07, 2008, 11:48:22 am »
What was wrong with the NTE part?
southpaw13
  • Whatever!
« Reply #13 on: July 07, 2008, 01:24:03 pm »
I couldn't find it either.  Mouser didn't have it.  I could have bought it from Happs or American gaming.  All three had a minimum order so I went with Wells Gardner since they are close to home.
Thanks for the help...
southpaw13
  • Whatever!
« Reply #14 on: July 09, 2008, 09:21:24 pm »
OK, the transistor on the neck board did not work.  Any other easy suggestions before I give up?
SirPeale
« Reply #15 on: July 09, 2008, 10:38:55 pm »
Touch up any and all solder joints on the board.  If you have access to a rejuvenator you can test the tube and see if the green gun is shot.  Check parts along the green circuit, see if anything isn't the way it's supposed to be.
Arm123
  • Last login:March 03, 2025, 11:26:20 am
« Reply #16 on: July 09, 2008, 10:48:39 pm »
You should see if you can locate someone with a CRT tester / rejuvinator to rule out the weak gun
SirPeale
« Reply #17 on: July 09, 2008, 10:54:15 pm »
I think I said that...
