Author Topic: Is it the wiring or the controller?  (Read 3106 times)
Dead Movie Star
  • Last login:July 06, 2008, 10:37:07 pm
« on: June 30, 2008, 03:22:33 pm »
I am making arcade controls for the Dreamcast and have ran into a little hiccup. It seems that when I push the A button, it registers as multiple buttons at the same time including the joystick. I have fiddled around with the wires, but then different buttons are pushed. I still can't tell if it is the solely wiring or the Dreamcast controller (a Mad Catz Dream Pad).
If it could possibly be the wiring, what can be done about it?
  • Last login:July 23, 2025, 07:04:20 pm
Re: Is it the wiring or the controller?
« Reply #1 on: June 30, 2008, 03:28:42 pm »
You've probably created shorts somewhere, most likely on the controller pcb itself.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #2 on: June 30, 2008, 03:29:40 pm »
That's wiring. Can you post pics of your wiring?
Ginsu Victim
« Reply #3 on: June 30, 2008, 03:30:14 pm »
Oh, HarumaN's here to help. You're in good hands.
« Reply #4 on: June 30, 2008, 03:30:58 pm »
Yeah, pics would be helpful.  A closeup of the PCB would help.
« Reply #5 on: June 30, 2008, 03:31:31 pm »
=D
I just did a pair of DC controllers for someone here this past weekend, lol.
Ginsu Victim
« Reply #6 on: June 30, 2008, 03:41:40 pm »
I figure if nothing else, you'll offer your services, and probably bump your thread in BST. ;)
Dead Movie Star
« Reply #7 on: June 30, 2008, 03:59:20 pm »
The mess is kinda embarrassing, but I ran out of wire. I'm just hoping it isn't the controller.
« Reply #8 on: June 30, 2008, 04:00:53 pm »
Shhh....   ;)
My wife won't let me get a PS3 unless I pay for it using PayPal...  I've got roughly $70 in there right now, lol.  Still a long way to go.   ;D
« Reply #9 on: June 30, 2008, 04:06:48 pm »
Hmm... your wiring appears to be ok... hard to tell.
However, your soldering on your controller PCB looks a bit messy, excess solder, and bare wires that could possible short circuit your buttons.  Do you get random button presses even if you don't do anything?
Can you get me a close pic of the a,b,x,y button area?
Dead Movie Star
« Reply #10 on: June 30, 2008, 04:17:08 pm »
No random button presses, just that cheeky A button.
Excess solder is an understatement, by the way.
Ginsu Victim
« Reply #11 on: June 30, 2008, 04:24:44 pm »
I'd make sure you don't have a splat of solder bridging a connection somewhere.
« Reply #12 on: June 30, 2008, 04:34:56 pm »
From the way that picture looks, I bet when you close the top of your controller the bare portion of your ground wire touches the bare portion of the A wire...  you may be getting more interactions elsewhere when the wires shift as the lid is closed.
Like Ginsu said, make sure you don't have any solder globs bridging contacts elsewhere.
Dead Movie Star
« Reply #13 on: June 30, 2008, 05:34:38 pm »
Hmm, I did put electrical tape over it once but it was still registering different buttons... I'll have to take another detailed look, I guess.
Update: I messed around with the wiring a little more and got it to work... under one condition.
This calls for even more electrical tape than before.
Thank god it isn't the controller, eh?
« Last Edit: June 30, 2008, 06:06:23 pm by Dead Movie Star »
Ginsu Victim
« Reply #14 on: June 30, 2008, 06:31:01 pm »
so is that just a mock-up before making the real one? If not, are you going to enclose it in any way? I see that thing falling over and your wires yanking loose.
« Last Edit: June 30, 2008, 06:34:46 pm by GinsuVictim »
Dead Movie Star
« Reply #15 on: June 30, 2008, 06:49:32 pm »
That's why I said "...under one condition." It's gonna be a nice little box that fits in your lap.
Ginsu Victim
« Reply #16 on: June 30, 2008, 07:54:39 pm »
Yeah, when I read "under one condition" I had no clue what you meant.
« Reply #17 on: June 30, 2008, 08:03:15 pm »
Same here...  ;D
You may want to consider some hot glue over your solder joints (its how I do it).  It will keep your wires from ripping up the traces on the PCB, and it can help you not get more shorts...
Jdurg
« Reply #18 on: July 01, 2008, 09:41:00 am »
I would highly suggest going to Home Depot and buying a bottle of the liquid electrical tape that they have, and covering any exposed wires with the liquid tape to prevent shorting.
Donkey Kong High Scores:
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
Dead Movie Star
« Reply #19 on: July 01, 2008, 09:57:54 am »
I made a discovery last night. If I put in a normal controller before plugging in my arcade controls then everything works fine. However, if I turn the console on with the arcade controls plugged in, problems arise.
That's messed up.
« Reply #20 on: July 01, 2008, 10:12:47 am »
Hmm... yeah, sounds like you have a short somewhere on your pcb.  Be careful with that...  shorts tend to cause the controller resistor in the DC to burn up (requiring replacement).  If all your controller ports end up dead one day, this is what happened.
Dead Movie Star
« Reply #21 on: July 01, 2008, 10:22:10 am »
I'm scared, mommy.
Edit: Wait, how can I be careful? Can I do anything instead of getting a new pcb?
« Last Edit: July 01, 2008, 10:42:34 am by Dead Movie Star »
Ginsu Victim
« Reply #22 on: July 01, 2008, 11:06:49 am »
Stop plugging it in, for one.
« Reply #23 on: July 01, 2008, 11:08:29 am »
Haha...
I was going to say a very close visual inspection.  Use a bright light and a magnifying glass.  Clean up any shorts caused by excess solder, etc...
Dead Movie Star
« Reply #24 on: July 01, 2008, 12:07:46 pm »
Haha...
This calls for heavy surgery. Might as well replace the wiring while I'm at it.
« Last Edit: July 01, 2008, 12:09:43 pm by Dead Movie Star »
« Reply #25 on: July 01, 2008, 12:17:59 pm »
Here's a pic of one I did...   ;D
Dead Movie Star
« Reply #26 on: July 01, 2008, 12:35:10 pm »
Don't you want to make sure it all works before you hot glue everything?
« Reply #27 on: July 01, 2008, 01:10:22 pm »
Don't need to.  I'm the Supreme Solder King...  8)
In all seriousness, I used to check each solder joint before hot glue, but after doing about the 20th or so hack, I just tested after everything was done (including the glue).
Ginsu Victim
« Reply #28 on: July 01, 2008, 01:34:39 pm »
Thanks for showing that pic. I'll have to keep that hot glue method in mind for my hack, plus other uses.
