Author Topic: "Lucky 8 Lines" Monitor (WG 19K7901)  (Read 5121 times)
« on: June 29, 2008, 08:07:53 pm »
I just acquired a poker type machine.
EDIT: It is a Lucky 8 Lines slot type machine.
It works but the monitor has bad burn in.
Can I use a PC monitor on it?
If so, how would I connect it?
« Last Edit: August 15, 2008, 07:23:04 pm by DaOld Man »
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
Re: Poker Machine Monitor
« Reply #1 on: June 29, 2008, 08:41:54 pm »
If it has a VGA monitor in there already, it's plug and play.  If not...no, you can't use it.
« Reply #2 on: June 30, 2008, 05:47:25 am »
It has what appears to be a molex connector with a few wires on it. (This is not the power wires).
How can I tell if it is VGA or not?
SirPeale
« Reply #3 on: June 30, 2008, 10:48:17 am »
Does it have a VGA connector on it?  If not, likely not.
You could also show us a picture, or pick your chassis off the chassis ID sites listed in the "READ THIS FIRST" post.
« Reply #4 on: July 05, 2008, 04:26:53 pm »
Im pretty sure it dows not have a VGA connector (like a PC one anyway).
I will try to get some pics/more info later..
« Reply #5 on: August 12, 2008, 10:41:00 am »
Bump..
The monitor is a wells gardner model #19K7901.
Im thinking that I probably cant use a regular PC CRT monitor in place of this one.
Does anyone make an adapter to convert the signal to VGA?
SirPeale
« Reply #6 on: August 12, 2008, 11:05:55 am »
Why don't you use the 7901?  It's a good monitor.
« Reply #7 on: August 12, 2008, 11:19:15 am »
Well, the picture on it is not too good. I adjusted the contrast and bright a little and got it better, but there is a metal piece close to the flyback that looks rusted. i think it may have been outside at one time. The cabinet is in bad shape, I can fix that. But I dont trust the monitor.
BTW, it's a Lucky 8 Lines. (Not a poker game but more like a slot machine).
« Reply #8 on: August 12, 2008, 11:33:45 am »
I was reading the FAQ and one post said the K7000A (I think) had two wires going to the high voltage suction cup on the CRT. This one has two wires also.
Do you think the model number stamped on it might be wrong?
SirPeale
Re: Poker Machine Monitor (WG 19K7901)
« Reply #9 on: August 12, 2008, 11:52:28 am »
So do a cap kit, touch up and bad solder joints, and have yourself a decent monitor again.
