Author Topic: wg u5000 with no red? Fixed!!!!  (Read 3878 times)
gatordad
  • Trade Count: (+11)
  • Last login:January 27, 2026, 09:36:47 am
« on: June 25, 2008, 06:34:49 pm »
I just just received a good condition 25 inch wg u5000 dual res monitor, however after putting it through it paces there is no red, I have tried all of the adjustment on the neck board but still I am missing red.
Any troubleshooting advice.
I have a 25 inch polo 1 tube laying around, would I hurt anything if I swap the tube out and see if red is still missing or is this most likely a cap issue on the chassis?
« Last Edit: July 07, 2008, 11:13:24 pm by gatordad »
grantspain
Re: wg u5000 with no red?
« Reply #1 on: June 25, 2008, 07:16:23 pm »
u5000 suffer from bad solder joints and bad drive transistors on the neck card
pretty sure the u5000 had a 0.600mh yoke so if you connect your polo tube you will fry the horizontal output stage :o
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #2 on: June 25, 2008, 08:59:24 pm »
Try swapping color transistors first.  U5000 (and the others that use that neckboard) are notorious for eating them.  Usually green, but any color is game.
gatordad
« Reply #3 on: July 06, 2008, 09:58:16 pm »
A few more questions
I am new to reading schematics  can someone help me before I order parts. Is the circled part a Q505 like I think it is?
I will be testing the tube hopefully sometime this week.
I had some time today to look everything over really well and I am completely missing this part, would this have been removed for any of the 3 upgrade kits available for this monitor, and for that matter how can I tell if the upgrade kits have been installed or not?
What do I look for?
SirPeale
« Reply #4 on: July 06, 2008, 10:16:28 pm »
Q505 is the schematic reference.  The transistor part number will be noted either in the schematics in the parts list, or on the transistor itself.
gatordad
« Reply #5 on: July 07, 2008, 11:05:30 am »
Ok I have the part # for the transistor (its npn sanyo 2sc3782)  but what is the part number for the (It looks like a heat sink that surrounds it)?
and how do I know if the upgrade kits have been installed or not?
SirPeale
« Reply #6 on: July 07, 2008, 11:07:17 am »
Just reuse the old heat sink.
gatordad
« Reply #7 on: July 07, 2008, 11:10:56 am »
I don't have it, its missing altogether.
SirPeale
« Reply #8 on: July 07, 2008, 11:14:35 am »
Gotcha.  Wells Gardner would have them.  But any small filled heat sink would do the job as long as you can attach it securely.
gatordad
Re: wg u5000 with no red? Fixed!!!!
« Reply #9 on: July 07, 2008, 11:21:06 pm »
I made a few calls to local arcade shops in the area, and found one that had the transistor and heat sink, I picked them up on my way home from work ( I even bought an extra just in case) 5 minute solder job, fired her up and I now have red, I spent about 5 minutes adjusting thing and now have a beautiful picture, I have to splice the power as the cab it's going into has a different connector for power.
Many thanks as if weren't for the helpful direction provided here I would not have know where to start looking.
What a good feeling...... my first solder job...... and monitor repair.
Now I want to cap something with my newly learned skills. ;D
