Author Topic: Help Identify what chassis goes to this tube  (Read 4733 times)
gatordad
  • Trade Count: (+11)
  • Last login:Yesterday at 08:30:46 am
« on: June 22, 2008, 03:54:48 pm »
I pulled this out of a Killer Instinct 2, it was missing the chassis.  :dunno I am looking for a replacement chassis that will work with this monitor, any ideas what this is.
grantspain
Re: Help Identify what chassis goes to this tube
« Reply #1 on: June 22, 2008, 04:30:48 pm »
the yoke wires are the non standard colours used by hantarex,do they go to a green 6 pin plug?
gatordad
« Reply #2 on: June 22, 2008, 06:49:57 pm »
the yoke wires are the non standard colors used by hantarex,do they go to a green 6 pin plug?
Yes the wires go to a green 6 pin plug but only 4 wires are connected 2 pins have a black wire looped like a pull handle.
You can see it here on the lower lt hand side of this photo, I could take another one it would help
It also has a remote adjustment board I could take a photo of that if it helps
Let me know
GD
Ken Layton
  • Guru
  • Technician
« Reply #3 on: June 22, 2008, 10:33:10 pm »
Probably a Hantarex "Polo" series.
grantspain
« Reply #4 on: June 23, 2008, 05:08:39 am »
looks like a polo1 but if you post a photo of the remote adjustment board i can tell for certain what model it is
gatordad
« Reply #5 on: June 23, 2008, 10:07:48 am »
I'll snap a photo when I get home from work.
gatordad
« Reply #6 on: June 23, 2008, 09:50:44 pm »
Here is the monitor connection plug and the remote adjustment board
Let me know what you think.
grantspain
« Reply #7 on: June 24, 2008, 03:29:10 am »
polo1
gatordad
grantspain
« Reply #9 on: June 24, 2008, 09:31:27 am »
yes the 8-liners will work,remember the yoke wires will be different colours though
gatordad
« Reply #10 on: June 24, 2008, 09:51:35 am »
Is there anywhere in the states that sells new / refurbished polo1 chassis?
grantspain
« Reply #11 on: June 24, 2008, 10:06:33 am »
hard to come by in the states i would imagine,i know that alva amusements have chassis to fit the hantarex polo 1
you need to quote the following
Tube size,neck pins quantity and the resistance of the vertical and horizontal yoke
Ken Layton
  • Guru
  • Technician
« Reply #12 on: June 24, 2008, 12:26:20 pm »
www.belamny.com is the only official Hantarex distributor in the USA. Contact them to see what they've got, but be warned that support on older Hantarex models is spotty at best.
Alva Amusement sells the Wei-ya model 826H universal replacement chassis that will work on your Polo. This replacement chassis requires use of an isolation transformer.
The original Hantarex yoke wire colors are:
Horizontal section is Yellow and Orange wires.
Vertical section is Red and Brown wires.
« Last Edit: June 24, 2008, 12:36:28 pm by Ken Layton »
gatordad
« Reply #13 on: June 24, 2008, 01:32:08 pm »
Gentlemen Thanks to you both
one last question
Do either of you know if the 8-liners chassis requires a iso transformer?
I read through the entire article and did not see it mentioned, I also looked here
http://www.8liners.com/datatech/monitor.html
and did not see any mention of needing a transformer, If you don't know I will call and ask?
Oh, as an additional thought.... does nieman sell replacement chassis?
Thanks again
grantspain
« Reply #14 on: June 24, 2008, 01:34:53 pm »
always worth giving rick a shout as he may have a chassis that drops in
grantspain
« Reply #15 on: June 24, 2008, 01:43:46 pm »
just to add that the link you provided clearly shows that the chassis does not have smps on board so it will need an iso transformer but i have seen other chassis from 8 liners that do not need an iso
