Author Topic: Anyone every replaced their furnace?  (Read 2691 times)
2600
« on: June 20, 2008, 08:33:31 pm »
Looks like I may need to replace my furnace.  Anyone have an experience with this or know what I'm in for?
Jdurg
Re: Anyone every replaced their furnace?
« Reply #1 on: June 20, 2008, 08:45:20 pm »
For parts and labor, I'd guess around $4000 or so, and that may be on the low end.  My parents had it done a few years ago and it cost them close to five thousand.
Donkey Kong High Scores:
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
mountain
  • Last login:January 29, 2025, 08:31:47 am
    • Mountain Jukeboxes
« Reply #2 on: June 20, 2008, 09:23:54 pm »
I had my furnace replaced in Feb. '07. They installed a new furnace (Trane), humidifier, new digital thermostat and cleaned all of my ductwork for $1800, including labor. My house is about 1800 square feet.
Blanka
« Reply #3 on: June 21, 2008, 01:49:24 am »
Do you US citizens get any of our European options there?
- 105% effictive hot water furnaces, with low-water-capacity radiators and CO2 regulated air-intake? (Hot air systems are so 80-ties and bad for the air-quality)
- compact warmth/electricity furnaces, that generate both heat and electricity
- 85% effective warmth conversion units between the intake of fresh air and exhaust of waste air
If I see a scheme of a "furnace" in google image search, it feels that you can save more than 50% on your gas bill in the US with simple measures.
Also have a look at things like Kingspan Cooltherm insulation. It has an incredible RC of 4 combined with 2,5 inch thickness.
« Reply #4 on: June 29, 2008, 05:33:37 pm »
What type of furnace is that?  Straight furnace or boiler too?  My furnace is pretty much end of life and I'm about to start getting quotes for a new one.  Straight furnace, hot water is external, forced hot air.
Jdurg
« Reply #5 on: June 29, 2008, 06:07:37 pm »
That would be for a furnace/boiler combination, and also depends on location in the house.  E.G. how much work is involved in removing it and putting the new one in its place.
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
Hoopz
  • Last login:Yesterday at 11:20:11 am
  • Intellivision Rocks!
« Reply #6 on: June 29, 2008, 07:13:05 pm »
Consider getting a heat pump also.  Takes less power to run it v. the furnace.  My heat pump runs by itself until temps get under 30 degrees, gets assistance down to 10 or 20 degrees, then the furnace takes over by itself under 10 (estimates on temps but fairly close I think).
« Reply #7 on: June 29, 2008, 09:42:31 pm »
Geothermal?  What was the installation cost?  Was it retrofit or new construction?  What state?
