Author Topic: 8-liners 25" Chassis Info  (Read 3784 times)
MK3FAN
« on: June 03, 2008, 06:44:59 pm »
For those of you who are on the fence with regards to purchasing an 8-liners chassis or have not seen one, here is a pic of the recent one I received. It's the 3rd one I have ordered and it's the 3rd one that works and looks great! You get new everything. From degauss wiring to monitor ground wire. Just wanted to share...
grantspain
Re: 8-liners 25" Chassis Info
« Reply #1 on: June 03, 2008, 07:03:24 pm »
thats a jen shinn dual sync-are you using this on standard cga tube and how much did it cost?
i am told these can fit any cga tube apart from sony
MK3FAN
« Reply #2 on: June 03, 2008, 07:17:54 pm »
I have two on a Wells Garnder Zenith tube and one on am RCA tube. All three are standard res. No problems with any of them. Here is a link to where to get one....
http://www.genao.com/osc/catalog/product_info.php?products_id=30
Brian Zellinger
  • Last login:July 08, 2008, 11:56:22 pm
« Reply #3 on: June 04, 2008, 08:10:09 pm »
I've read that it supports some 27" tubes as well. Can anyone tell me if this will work with a WG K7500 and U2000? Both 27" The K7500 is medium res and the U2000 is standard.
Dual sync? Does that mean standard and med res?
grantspain
« Reply #4 on: June 05, 2008, 04:32:12 am »
i am not 100% sure this is the jen shinn dual sync but it really looks the same,be good to find out for certain as i know these fit on 27" tubes
Ken Layton
  • Guru
  • Technician
« Reply #5 on: June 05, 2008, 10:21:33 am »
Jen Shinn's website does not mention any chassis models for 25" tubes. They have chassis shown for 14 to 20" and the next group of chassis are for 28" to 29" tubes. No mention of 25".
Brian Zellinger
« Reply #6 on: June 05, 2008, 11:55:39 am »
grantspain
« Reply #7 on: June 05, 2008, 12:07:44 pm »
CGA only:
http://www.8liners.com/datatech/monitor.html
that looks like a different chassis,jen shinn chassis all have white flybacks apart from the dual sync which is black
hantarex use the same chassis for 25" as 28" which leads me to believe this could be the same
like i say it would nice to find out for certain
Ken Layton
  • Guru
  • Technician
« Reply #8 on: June 05, 2008, 06:11:43 pm »
As I recall, 8liners was using a Wei-ya chassis for 25" tubes.
alienware32
  • Last login:September 26, 2009, 05:28:40 pm
« Reply #9 on: June 24, 2008, 11:17:09 pm »
is this chassis better than the weyia 826 i have
gatordad
  • Trade Count: (+11)
  • Last login:March 15, 2026, 02:09:42 pm
« Reply #10 on: June 25, 2008, 12:09:26 am »
Do you need an iso transformer with this?
grantspain
« Reply #11 on: June 25, 2008, 03:47:06 am »
i am pretty certain that does not need an iso as i can see the mains transformer on the chassis,if you see on the specs that the voltage is 80-240vac then that means an iso is not required
to be certain just contact the supplier and ask for all the specs of the chassis
