Author Topic: MaLa Plugin announcement: MaLa Launcher 1.0  (Read 3656 times)
TheShanMan
    • My Arcade (updated 1/30/13)
« on: May 31, 2008, 12:23:22 am »
Do you run MaLa as your windows shell? Do you wish you had a good way to launch background tasks (like CPWizard) when windows boots up, without having to resort to installing a RunAsService type of program? Well here's the answer...
Install this plugin, create a "Launch" subdirectory under Plugins, and put some shortcuts in there. They will be launched when MaLa starts up, just like the start menu's Startup folder does if you have explorer as your shell.
It can be found on the MaLa plugin webpage: http://malafe.net/index.php?page=plugins
Enjoy!
loadman
  • Moderator
  • Last login:January 29, 2026, 07:18:10 pm
    • MaLa
Re: MaLa Plugin announcement: MaLa Launcher 1.0
« Reply #1 on: May 31, 2008, 12:30:59 am »
Nice genric plug-in dude  ;)
FYI This is not to be confused with DaOldMan's upcoming plugin that will launch athe .exe of your choice sending extra paramater of MaLa's orientation upon MaLa start (eg to a program rotate a monitor)
http://forum.arcadecontrols.com/index.php?topic=79789.msg833315#msg833315
