Author Topic: Source for cheap DB-25 cables for control panels?  (Read 1264 times)
pmc
  • Last login:December 20, 2023, 07:43:02 am
    • website
« on: May 21, 2008, 01:42:03 pm »
I'm ready to convert my swappable panels from 50-pin SCSI to 25-pin DB25 connectors. The internal SCSI cables just don't make good quick disconnects (they haven't held up well) and I can't use switch-boxes or make fancy connector blocks, or expand easily. Time to redo this mess.
Anyway, I need at least 4 good quality 3-6 foot straight-through cables with color coded wires. Some of you probably just sourced some for your cabinet. Can you point me in the right direction? I don't want to spend too much on cables that I'll just cut in half. :)
-pmc
Re: Source for cheap DB-25 cables for control panels?
« Reply #1 on: May 21, 2008, 02:16:57 pm »
Check mouser.com, lots of varieties and lengths, not too pricey.
ahofle
    • Arcade Ambience Project
TheShanMan
    • My Arcade (updated 1/30/13)
« Reply #3 on: May 21, 2008, 03:19:38 pm »
Check out PCH Cables (http://store.pchcables.com/serparcab.html). They've got great prices. His shop is just down the street from me, though most of his sales come from online orders. He's a great guy.
If DB-37 cables are appealing to you (I used them for my swappable panels), then Winford is your place: http://www.winfordeng.com/products/cat_cables.php.
pmc
    • website
« Reply #4 on: May 21, 2008, 03:39:02 pm »
All good leads. I was actually going to order from monoprice.com just before I posted here. But I wanted to be sure I'd get straight through cables with color-coded wires. Can you guys confirm that all these cables are likely to be color-coded? Or am I just being silly about this?
-pmc
Cakemeister
  • Last login:May 31, 2024, 06:23:16 pm
« Reply #5 on: May 21, 2008, 03:41:27 pm »
Another vote for Winford. I don't think you will find color-coded cables, though.
Old, but not obsolete.
pmc
    • website
« Reply #6 on: May 21, 2008, 04:21:28 pm »
So I have to tone out each wire? I'm not against it, but I've seen cables with colored wires. Makes it easier to identify what is what. I guess I'd still tone it out to make certain I have the right wire.
I just didn't want to end up getting wacky cables that will make me pull my hair out...
-pmc
TheShanMan
« Reply #7 on: May 21, 2008, 05:42:38 pm »
My cables (from both PCH and Winford) are color coded. Knowing what pins the colors correspond to is another matter. I just used my multimeter to figure that out - fortunately it makes a beeping noise when there's near zero resistance.
pmc
    • website
« Reply #8 on: May 23, 2008, 02:05:09 pm »
Perfect. Thank you.
-pmc
