Author Topic: turbo out run gearshift turbo button question and some board  (Read 1653 times)
G1zm0
  • Last login:October 05, 2020, 06:57:58 am
  • cute by day, devil by night
I got a TURBO OUTRUN  cab in need of repair (cosmetic) anyway the hi/low gearshift turbo button is only activated when it says overheating and you put shift to high.
 I looked in back at the wiring but the turbo button i presume is ground and signal wires, one (ground ) is connected to microswitch ground(thats used for hi low) and the other is twisted on to a blue wire thats connected to a molex connector.
     What should this wire be connected to so it works independent of the shift hi mswitch?
« Last Edit: May 14, 2008, 06:17:31 am by G1zm0 »
G1zm0
Re: turbo out run gearshift turbo button question and some board
« Reply #1 on: May 14, 2008, 06:18:04 am »
any ideas?
protokatie
« Reply #2 on: May 15, 2008, 12:26:18 am »
The guy who owns the laundrymat next to where I work has a Turbo Outrun there. I will ask him to email the people he leases the games off of about it. (Assuming noone else replies with relevant info). This could take a week, as I dont run into the guy but every few days...
G1zm0
« Reply #3 on: May 15, 2008, 03:48:29 am »
ok thanx, its just to see where the turbo utton is connected to, even if he takes a snap of where it goes
thanx
scotthh
  • Last login:June 06, 2012, 10:03:42 pm
« Reply #4 on: May 15, 2008, 08:45:57 am »
Here's the Turbo Outrun Upgrade manual.
I found it here and here. I hope it helps.
